Anywhere but centreline
One sour experience, many moons ago = Never again. No one is allowed to use that workshop on your watch.
Good thing you never went to Rajab, or the last few years of RE Customs
Centerline.... Can't go wrong. Your side of town as well.
As far as Toyota boat specialist... 612 Autoworks is a garage business doing lots of crowns, cressidas and chasers.
my preference is to take it somewhere use to dealing with cars that aren't worth about 15% of the value of my car
Ie ya standard young 'enthusiast' shop
Edited by alr33x
MaseratiOz forum is thata way --->
  • Like 1
Should I reccomend a shop that tried to BLATANTLY rip me off, and also my mate just because they work on some old POS mazda race cars?
So, as mentioned, go to centerline where they are used to working on race cars worth about 3 times as much your lexus
  • Like 1
Did good work on my pulsar a whole bunch of times and did a proper job with the Gloria.
Maybe they didn't like how you carry yourself. It's west side after all. Next to Hells Angels HQ
Well Dezz said its shit so must be shit.
Shoulda known asked in the wrong place ere
Not worried about race cars etc but I've seen how the workers treat every car the same lexus, skyline, Audi, VL I'm not interested in those places
From what I've seen / experienced:
RTR = Low by a few percent
Racepace = Low by a few percent, and not an accurate torque figure (its calculated via road speed, with no tacho input)
Chasers = Fairly Accurate
Trent = High by approx 10%
Thats why when I had an RTR tune at 255rwkw I'd tell people "255, so about 270 on trents for comparison"
At the end of the day though, who gives a crap what the figures say... What you want is a Pre-Tune overlay on the final printout so you can see the difference in the shape / area under the curve.
And lots of people always seem to forget that when you roll out of the shop, if you're actually running the same tune / timing as your max power run then your car MAY last until the end of the week, or until a slightly suboptimal batch of fuel / hot day.
RacePace usually give you a max power run just for potential then dial it back for safety; pretty conservative tunes IMO
But most tuners who have been around a long time are these days, unless customer requests every last kw - it's not in their interests to have customer cars shattering pistons
My mates car with the same mods as mine made 297kw on 98 at chasers with mine beng 10k less at trents.
We threw it on the dyno at dr drift and the afr's were 14.5 and climbing at 4000rpm when we pulled the run
Chasers CAN be good, but if they dont know you.......
That's great, you want to recommend them based on your experiences, I'll tell people not to go near them because of mine.
What kind of expert charges $X (overpriced at that) for a service, then tells that customer their setup is a mess, and asks who set it up... That's a quality workshop.
  • Like 1
Hate to break it to you dude, but they ARE all the same...
Especially a toyota with an L badge
As I said centerline work on cars worth all sorts of coin including high end race cars with rediculous suspension setups
Not really all the same big difference jumping in a 20 year old Nissan with ya dirty clothes and a car with white leather
But anyway
An apprentice driving a 10k car or a 100k car
I don't see the same same approach myself, not to mention IF something goes wrong the shitty shops will probably not even pay to fix
Edited by alr33x
    • Fark what are the changes of that snapping like that, clean. Nek minnit, custom radiator goes in, with built in oil cooler like those discontinued PWR ones from yesterdeacades ago
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
