It was about as serious as the prospect of taking an a5 to a workshop that we frequent to get it done...
Either put some trust in a euro workshop to do it, or don't modify it...
Now, this is a story all about how
My life got flipped-turned upside down
And I'd like to take a minute
Just sit tight and wait
I'll tell you how I became the prince of a thing called Real Estate
In western subnurbs born and raised
On the hard clay ground was where I spent most of my days
Chillin' out maxin' relaxin' all cool
And tellin everyone they dont need to be schooled
When a couple of illegal immigrants were jumpin the border
Started making trouble all up in my corner
I got in one little internet fight and my mom got a look
She said 'You're movin' with your auntie and uncle in Point Cook'
I begged and pleaded with her day after day
But she packed my lexus and sent me on my way
She gave me a kiss and then she gave me my keys.
I put my Tupac on and said, 'I might as well leave'.
First class, yo this ain't bad
Drinking burbon cans out of a champagne glass.
Is this what the people of Point Cook living like?
Hmmmmm this might be alright.
But wait I hear they're Labor, Left wing, all that
Is this the type of place that they just send this conservative cat?
I don't think so
I'll see when I get a look
I hope they're prepared for the prince of Point Cook
Well, the policies lowered and when some gays came out
There was a dude who looked like a flog standing there with big ears sticking out
He said gays should be arrested like illegals that just got here
So I discrediteded some memes of eating onions and skolling beer.
I whistled for a lexus and when it came together
The license plate said Sherwin and it had luxurious white leather
If anything I could say that this lexus was expensive
But I thought 'Nah, forget it' - 'Yo, Labors economic mismanagement was extensive'
I pulled up to the office and there was this fob
And I yelled to the unionised leftie scum 'Yo flog get a better job'
I looked at my kingdom
I was finally through the gate
To sit on my throne as the Prince of Real Estate
  • Like 1
The point isn't because the car costs more, even when I had my 33 didn't want it treated shithouse - which it was regularly. unfortunately the industry is a bit substandard in that area IMO.
So much butt hurt from the battlers
Good see tall poppy syndrome is alive and well
Tall poppy syndrome is attempting to cut someone down ONLY because they are successful and one is jealous of same.
If you hadn't spent the last month bragging it would have been TPS
FWIW I get that you are trolling... but it was too good to pass up
Ya'll too easy tho mention a couple dollars erry body lose they mind
point still stands about wanting a decent work shop tho
Edited by alr33x
Try making a booking at zagame's Richmond.
srs.
Will coilovers void Lexus warranty? I know warranties can be funny with "expensive" cars.
Not doing cool overs thought about it but too much headache and lose the adjustable dampener bs. Just springs they give it 1.5" all round which is pretty much perfect for everyday and will sit nice with 20s
Coils look hot tho
Coils look hot tho
Unnnnffff! That does look good... What colour is yours again?
Do you ever have clients in the car? Will a 1.5" drop lower ride quality enough to bother them?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
