need to get a valve replaced in a Tyre when I get home, any idea on how much?
it either the valve or the rim...
had a slow leak but the tyre was getting old replaced and the slow leak still there, so assuming valve or fked rim.
Last time I got a stuck valve replaced on the skyline it was free... They came out with their valve replacement tool, took off the valve cap, unscrewed the valve, screwed a new one in... Took 5 seconds, didn't even jack the car up or anything. Just replaced the 10psi of air that it dropped during the changeover.
If its the valve stem not sealing though, then thats a tyre-off job.
Also, if its the valve, then you shouldn't be losing air if you've got decent valve caps on.
Have a look at the valve stem when you get home and see if it looks new, a lot of tyre shops will replace the rubber stem and valve when they fit a new tyre.
Def not replaced.
Should probably look into some blue rays valve caps
interesting...but prob cheaper to buy a replacement ute.
could be the seal around the valve or a bunch of things, last time I got tires on the 200 they checked and the vale steam steal was cracked and perished, so it got new ones at the time.
and yeah they cheap and nasty plastic caps
Replacement ute doesn't come with a Free Instagram account and a boyfriend though...
Buy the Blue Rays valve caps, you can have all of these things and more.
LMAO!!!!
So last night I got some immunisations and threw a post up on FB taking a jab at Anti-Vaxxers... This morning I spot a Facebook Message sitting in my "Others" folder from some ransom person (friend of an international friend) saying "You won't be laughing when your children become retarted due to the governments lack of due diligence!"
1. Yes, she went out of her way to send a message to someone she doesnt know.
2. Yes, she's in an idiot.
3. Yes, she's "retarted"
Dat great weather, prime time to go and start enjoying a car...
..shame I blew the head gasket/cracked the block/lifted the head 7000kms after paying 12k+ to get the engine re-assembled last night!
the cycle cannot be broken
I don't think this was caused by you being Greg, I think this was caused by that abortion of a sentence.
LMAO!!!!
Or some aborted foetus's stem cells
Just saying. :D
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
