Are these circuit familiarisation days worth it the day before track days?
And by this I mean in terms of how fast you're allowed to "familiarise" yourself, if the passenger laps are limited in speed and what etc. How much time on the track? Nearly doubles the price of a track day but curious on the worth of it beyond getting to know the lines.
So pulsar basically has 3" intercooler piping everywhere except straight out of turbo and a 0.5m section after the intercooler cold side. (Intercooler and intake are 3"). Would it be worth changing that section to 3"? Would it be a bottleneck or just a source of heat? If manifold pressure is 20psi for eg, then this section would be higher I guess.
3 inch will flow 600kw, sounds like you are going overkill to me...
LAG for days... :P
Sounds like a massive waste of time/money to me.
First session is always a bit slower anyway... track may be a bit slippery in the early morning, your tyres aren't at the right pressure / temperature. So I always use the first session to cruise around and warm things up, get re-familiar with the track and then I come in, immediately check tyre pressures and set them to where I want them to do... Then Session 2 is my first actual fast one.
Might be worth going along to a day like that if it is 30 cars and heaps of track time, or they have professional instructors who can show you the fastest lines
Have spent over $1000 on artwork over the past couple of days. Getting old. #houselyf
Poor r32 looking untidy
How's houselyf for you Leigh? More interested in furniture than car mods haha
SELL ME THAT CAR
  • Like 1
Haha yeah I went through the same phase, I just spent $143 on framing a few pictures from a Phillip Island track day to put in my 'study / mancave' alongside my Lorenzo / Hayden frames..
Got a Joker canvis for my HT room recently too.. #housemods
Also dat furniture $$$
Trying to afford/justify a cat back for the car atm..
Edited by UNR33L
  • Like 1
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
