pho is soso. unless you get the beef raw on the side, and a bowl of the oil they skim off the broth and pour that right back into the soup. oh yes. then add chilli.
BUN BO HUE IS WHERE ITS AT
with lots of chilli. just spam that shit.
BBH is a close second for sure.
When I had pho in 'nam I paid the woman extra to dump a shitload of meat in there so it was effectively a swamp of meat, but at least it didn't taste like dishwater anymore
been there
turned out the "meat" was stewed cow heart tho..
with ant infested bread.
otherwise we would normally go the the local Bún Thịt Nướng place.
forget this corriander chilli or seasons, it was noodles, pork cooked in the gutter and some flavorless soup.
but we could eat for around 50c each.
so local food there was the exact opposite to local food in italy,
Your Vietnam experience looks very different to mine lol
That's probably because he didn't walk into the first bar he saw and ask for cock
went "urban exploring" last night.
unused nursing home that i wouldnt call abandoned, because the garden was well maintained, lights still worked etc.
anyway, ended up on the roof and found someone had set up some chairs haha.
awesome view of the city!
  • Like 1
so you broke in to someone's place.... you should probably post that on the internet
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
