So they give you a 20% pay cut for 4 years, then pay you 80% in the 5th year when you're not working, presumably when they forecast they'll have no work for you anyway...
Say you're on 100k, they cut that to 80k for 4 years, saving themselves 80k over the 4 years, they then pay you 80k in the fifth year to have the year off... So they've saved themselves $100k per employee, and all you've gained is a year off, with $100k less in your pocket than you would've had on normal terms
Sounds like a good deal...................
Tall them you will do it but you need to take the gap year first then quit before you go back or just get a job somewhere else.
Clearly they will never let you do it that way though
Take the cynical blinkers off Monica
They haven't saved $100k per employee, they've gotten 4 years of work out of them and paid out $400k either way
And that mere year off could be spent on a beach with a European woman, not stuck in traffic in Tarneit
Tell me someone on 80k is going to happily doing workload of a 100k position?
100k for 5 years = 5 years of work for the company and $500k in your pocket (before tax)
vs
80k for 5 years = 4 years of half-arsed work for the company (They'll need to take on another employee to cover the 5th year so they're out $600 instead of $500k), barely making your house payments if anything goes wrong in your life (sick family, babies, etc).
What happens if situations change and you want to change companies after 3 years? Do they need to pay out 60k pro-rata on your last day? Thats a huge financial liability for the company.
vs
Considering last couple companies I worked for complain if you have more than 20 days annual leave owing...1 year hell no
She'll leave you pretty quickly once your 80k runs out and you're sleeping in that same beach permanently
The concept isn't a bad one. It's like working 3 12 hour days a week for 36 hours and then having 4 days off, just on a grander scale.
What if it was 10%, instead of 20%? Having a year paid off ain't such a bad idea, because unlike the VWL regular elite most don't actually plan that well because life tends to get in the way.
vs
Company pays you $400k over 5 years as your 5th year is unpaid but supported by the 80k saving you accumulated over the 4 years.
The company will then hire an additional person at $100k. So the end cost is the same for the business. $500k.
Well yeah cos I obviously wouldn't undertake any financial planning or change my lifestyle at all
I should just go to work and take zero risks, what was I thinking
  • Like 1
I went from EBA hourly rate, 40 hour week with fortnightly RDO (paid 36 hours a week)
to
Salary, the worlds most complex over-time system, no RDO's and monthly pay.
to finally
Hourly rate salary, OT penalty rates, no RDO, fortnightly pay.
(^ best). RDO fortnightly was a joke, couldnt run a site properly or finish a job as planned. I prefer the extra paid hours.
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
