Dream boats.
Ex-mate who sold his pulsar to get a VW, going on about his mates having 400kw Audi, golf R this, GTI that.... Bah. 400kw won't save you when your car puts itself into limp mode from a wind screen wiper electrical fault
Did you ditch him as a mate cos he sold his pulsar?
That and he would ask me a million questions about car parts and modifying, then back out of purchasing my bits.
Contemplated selling his car for over 12 months, then gets a $250 stainless intake pipe made up for stock afm and air box :rolleyes:
A mate bought an S3 with 40,000km on it or something
Raced him, beat him by a fair bit
He took it to get that stage 7 ecu remapping bullshit that Audi owners do, said his car would be a good match for mine now
I switched back to E85 and beat him again
Thing sounded like it was farting every gearchange, had some intake leak problem too that kept hissing and only he could hear it
Sold it 2 months later lol
Moral of the story is that anything produced by VW is a piece of shit
Moral of the story is that anything produced by my anus is a piece of shit
tell me more please
I don't know what to think about this one lol. It just seems to far fetched to be true but on the other hand, it happened... it would have to be highly organised so there must be some form of political notice behind it which I assume will become apparent in coming days
It just seems strange, when you think about it, given the abuse of immigrants has been typically one-way (blaming them for existing and trying to stay alive)
But this one is a real head scratcher indeed. Obviously you can't say WELL I GUESS IMMIGRATION DOESNT WORK BETTER CLOSE THE BORDERS! over it, but.. yeah..
What's the going price for a big single r32 Gtr in really nice condition these days?
Guy wants to trade, has a blown box which is an easy fix. Might be a good deal considering I paid 16k for the bummer
Here is a clean r32 gtr which is Birds approved.
http://www.sau.com.au/forums/topic/456219-1994-r32-gtr-vspec-2-white-nsw/
Thinking of getting a VE SS or similar as a daily...
Want something that can tow, and then de-rego skyline / drop insurance costs
Anyone driven one long term?
Pro's / Con's?
Go.
what a beautiful car.
im seriously considering going for this R32, pictures show it looks great, gonna go and have a look tomorrow.
would make a tidy profit once i get the big $$$ bits onto the sedan
Pro's / Con's?
Go.
pros:
big motor, big burnouts
cons: youll start thinking your sisters hot.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
