im after a hire car mate, not a male escort.
pulsar/corolla. 3-4 days. pickup at Surfers, drop off at airport. Webjet is saying Keddy's. Drivenow.com.au is Keddy's but $10 cheaper, or Europcar.
  • Like 1
Not sure which is more gay
  • Like 1
Europcar were good to us with a Micra, but just beware of and check the insurance excesses of all companies, because most of these companies will have ridiculous excesses if you don't pay an extra $100 premium for no excess etc.
All stories of tragedy like that do is remind me (not that I needed reminding) how ridiculously fked it is that our biggest newsworthy problem a week or two ago was a sportsman asking an interviewer out for a drink
Priorities
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
