https://www.youtube.com/watch?v=gDn-dGq_0ak
straya'
the word 'invitaional' lel
ofcourse the first guy they introduce drives a decked out bmw with dat dere 'FIFO' job
Haha
Oil & gas money - probably based on an offshore rig.
Big money - much more than dem iron ore
Offshore is a pretty shit gig. Would be good to try one stint though.
Speaking of shit gigs, my uncle just finished up after 3.5 years FIFO from Aus/NZ to Egypt. 2-3 days travel each way, dinner was boiled chicken every night (5 different varieties over the week), 50 degrees in summer, 6-8 week stints (and longer stays if required). His 30kg baggage was all food so he could cook in his room. Hes been doing shit like this for 30 years or something, been married 3 times, and 6 kids... A hollow husk of a man.
he doesnt really show it. ex-wives milked him for most of it i reckon.
though, apparently his current house was rented out for $750/week before he bought it. prolly paid straight ca$h.
doesnt have a jet ski. used to have 2 alpacas.
i think only camels and llamas spit?
whats the going rate for attendance for a bucks night?
just paid $180. not telling us what activities are planned, but includes a bus and bar tab at one place.
Depends if an overnight stay is involved or not
A day/night thing up to $200, overnight sharing a house could be $250-300 all said and done
I'm getting sick of weddings though. Above costs, plus wedding gift and hair/makeup/dress for the girlfriend. As a couple it can cost you shitloads.
/subtle
/subtle
Wait till you actually get married...
Speaking of outrageous expenditure
No this isn't a dig at Labor
What are the VWL romantics doing on Sunday ?
buyin than bitch a tattoo
bitches love tattoo's
doing a nice dinner for us... have some dry aged cape grim scotchey's in the fridge
1. Why are you pulling your motor?
2. Don't you have goats?
replace a few gaskets and shit.
the dude i had paid to finish it all off and put it in the car made a mess of it.
so out it comes for brand new hoses and seals. again.
council took my goats :(
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
