Birds my way to get that turbo rush of power out of nowhere is to get dat dere foot turbo lag makes you realize that it pulls, either that or sit 4000rpm then stomp the throttle for that instant throwback.
That awkward moment when a walkinshaw gts goes you off the line when you've just started driving and tyres are rock icey cold, skated all the way up Blackburn road near Monash playing catch-up. Then on roll he bitched out when I was aware
so... you lost?
I see 88E is still on a stride..
https://www.google.com/?gws_rd=ssl#safe=off&q=88e+share+price
Depends which time span you're looking at...
Daily is fine, everything else.... not so much.
88e train de-railed, goodbye old friend $
rip $$
Hello darkness my old friend...
Anyone invested should be using the opportunity to buy more while cheap; share price down but the fundamentals have not changed, only improved. DYOR, not financial advice blah blah
Edit: London up so far today; this might have reached its floor
yeah it had fallen further tho so needs to stabilize.
that said with the News from Qatar over the past couple of days new Oil deposits are not making money.
Iran is Fkning the market with oil
it prob has LONG term chance as you said but nothing short term as far as I can see,
They can't hold that up for too long; literally selling themselves out of a future like the Saudis. Oil price has been making a very good recovery and ultimately it's a finite resource that the world will still need for decades. They aren't making any more of it, so whether a year or 5 years this reserve we have of a billion barrels plus is quite something.
As for little 88E, at the recent investor presentation they've said at current price of oil it is profitable; they have joint venture offers on the table, but want a better deal/s to maximise value for shareholders (themselves included), so will continue proving it up to get more interest and better leverage. Personally I'm not interested in the short term share price for any reason other than to buy more shares for cheap, but recovery does help with new traders who aren't used to seeing their money in a paper loss.
2-3 days ago .050 was the 'new floor'
Test of time - this "floor" may not last either...could go back up to .050 or could sink down again. Need a good few weeks of averages to find out where the real floor is. Honestly don't think it has one, it's too volatile and there's too much happening with the company. Seismic due in June and at any moment a joint venture could drop and be a game changer. Lock your shares in the bottom drawer.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
