I actually got lucky charms from Naples in the car now. They are a very superstitious people. I also prayed at a Shinto temple for my car too. Doesn't seem to help much.
Temptation is strong to sell and buy supra/mx5 turbo/something else, but car actually is quite good, just less than the sum of its parts due to something always being almost working.
That said, did go for a ride in a 400awkw well sorted GTR with about 50k spent on it, all done at Racepace and thought "meh, I prefer mine actually" so it's not like it's a complete bucket when running.
great success hifive
I'm still brainstorming my retirement project of convertible with ITB N/A SR20 RWD (or FWD, but think RWD would be more fun). Originally thinking Sunbeam ratrod-ish, then thought old skool Nissan Fairlady and it would be awesome but aint cheap and all are LHD plus tiny engine bay. MX5 would be the easiest option but i just hate looking at them and every man and his dog has one and i dont think i could ever own one.
To be fair my only experience was due to gf wanting to get into cars and "What would you recommend?"
And I said MX5 for all the reasons everyone always 'says' MX5 though I had never driven one.
Then I did, and I'm like ... this is the most fun little car ever.
There's a wild amount of support for parts through pages like http://www.mx5mania.com.au
Just... SO EASY to get parts, bolt on, info is everywhere.
Given a stock one makes like 60rwkw, having 165rwkw with some sticky tyres would be an absolute blast, these things are just toys after all, if you focus on FUN instead of being fully sick and super cool looking man it's hard to beat the little MX5.
But yeah I still feel silly stepping out of one, the stigma is real. (but entirely undeserved)
Thats the other thing that makes my retirement project sounds stupid is the S2000 is basically what i want. Maybe a little smaller and lighter. And easier to work on. And i want to build another SR20.
How tall are you? One of the things stopping me from acquiring that or an S2000 is the height factor.
This is why i don't have one
I have to go custom fixed back and remove the bottom half of the dash.... so... yeh
On the bright side there is no back seat to fall into. Just pull out the seat and put a towel on the chassis.
  • Like 2
Do want a turbo MX5 SE
went in one on the skidpan and was BLOWN AWAY
MX5 SE only has like 100rwkw, with a tune they are 165ish which is about the limit of the block, but.. for the lols, it'd rock! I can't honestly say I'd rather drive a 400rwkw skyline over a 165rwkw MX5 in doing a track day/hill run/going to the shops, etc.
I am 6'2 but my friend is 6'5" and fits into a MX5 with no issues. It's all in the seat and where you set it. There is a SUPRISING amount of room, unless you are literally the mountain, you can fit in a MX5.
I also would prefer a SE with a chip over a S2000 - the MX5 is just simple, easy, and smaller/lighter than the S2000 and going off "the forams" it seems that at the limit the MX5 handles a lot better than the S2000 does. Parts are cheaper, easier to find, so much knowledge, cheap, small, simple, etc etc.
And most importantly.... fun
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
