i got southland carwash to steam clean my now-gone pulsar a while ago. Seats turned out good, but they sprayed the entire interior (radio and everything) with some shitty washing product that stayed sticky. I had re-go over everything with a damp cloth to get the stickiness out. it was like a pink, nice smelling soup kitchen happened inside the car. They even accidently left a bottle of it under the drivers seat. spastics.
1 hour ago, joeyjoejoejuniorshabadoo said:
You literally just bought an R32 in the exact condition as the car the guy is making inquiries about
nah the new one is worse lol.
its pretty bad but saveable .
1 hour ago, Kinkstaah said:
Dumb question, is there any good BUDGET detailers? Somewhere where you can just go on a very low notice and get a reasonable to OK job of interior detailing because majorly CBF and car looks pretty shit 95% of the time anyway?
By "good enough" I mean good enough to think "oh yep, that's cleaner now" but with 0 desire to actually take a photo of it.
In springvale cnr of westall and osbourne i think? next to GT hyperauto
$15 for a hand car wash. not bad considering it takes em like an hour
I wonder what the IT section at Telstra is like....
Would it be filled with ex-public servants who just dont give a fark and do nothing all day.
Or would it be generally younger IT personnel who just dont give a fark and do nothing all day.
Or would it be a small team of extremely over-worked individuals that are constantly putting out fires and trying to resolve the countless issues that arise?
All of the above.
I took the 33 to a shopping centre carwash when i first got it.
dude used a pressure sprayer at close range to remove a birdshit and stripped a soccerball sized bit of paint off the bonnet
That just means you had shit paint doe
  • Like 1
S13 convertible in manual. i kinda like it because its stock? maybe thats what happens when all you see are S13 drift cops anymore
http://www.carsensor.net/usedcar/detail/CU5088407384/index.html?TRCD=200002
id love a stock s13 vert with the aero kit and R33 GTR wheels= porn
also, good mate of mine stacked his car last night, after a bucks party, into a house.
f**ked the house, nothing left of the car.
i really hope he just fell asleep at the wheel and wasnt being an idiot :(
the extent of the damage though, i doubt it.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
