Xforce Varex exhaust systems road worthy? Seem to recall close able valve exhausts not being road worthy for some reason, but double checking given its a standard feature on plenty of cars including mine... Brother is thinking about getting one for his mustang but personally I think it's a waste of money paying for something I'd never use, and more so if it's illegal in itself anyway...
So apart from the possibility of closing it around a cop car in an attempt to avoid being sent to the epa, it has no actual upside if you are sent to the epa... Unless it's under when fully open, in which case it's pretty pointless.
Given my brother is 35 and doesn't hang around the local maccas car park, he'd be better off getting a normal exhaust which is probably cheaper
Factory exhaust technology = road legal cause engineered blah blah and exceptions just like HID in factory cars and Harley Davidsons being ridiculously loud from the dealership.
Aftermarket / varex = technically not legal, even if it's under the limit when open...as far as I know...many cops will treat it as a defectable item.
Workshops...who knows...when I got an EPA done the guy said he had to test it with it open. 107db. So had to remove and put stock exhaust on to clear.
A friend of mine finds their varex useful and uses it all the time, not just around police but for not bothering neighbours late at night or eliminate drone on freeway driving etc. Some people just leave them open full time though. Varex + hotdog mid muffler is a good combo.
You broke the speed limit, why do you think you should get off
Because I'm a law abiding citizen who has drastically improved my driving record in the last 5 years. Rather than get cheaper rego (the logical reward), I get off one minor offence every 2 years
I've been thinking of varex-style solutions because straight pipe SC430 sounds like fun, but obviously only at the right time/place (3UZs are notoriously quiet even with straight pipe, compared to other V8s).
Driving behind one of those Porsche mini SUVs and I noticed the outer exhaust tips have motorised valves in them, if fitted to a cheaper car might be a worthwhile wreckers find.
Write a letter - admit guilt and misunderstanding. Will get official warning if clean record.
They won't let off anyone who runs a red though
Only if less than 10kph over
Also there is a specific template letter you have to use for some reason
  • Like 1
The EVC is still available for purchase from Nengun.
https://www.nengun.com/apexi/exhaust-control-valve
Also, viewed a car today... getting it checked out by State Roads on Tuesday, fingers crossed its all good.
2 hours ago, joeyjoejoejuniorshabadoo said:
The manual apexi valves are way better, but discontinued now.
uwotm8?
That's like saying those remote control cars that - didn't come with remote controls - the electric ones you just turned on and they just spun the wheels until they crashed - are better than actual remote control cars. f**k you very much.
Seems odd to do something so simple with an electric motor and crappy Chinese products charged at a premium. I was thinking of having it early in the system and be more of a bypass valve, not like a muffler that blocks flow when closed
    • For fuelling the Haltechs have O2WB fuel controllers. Very useful for helping tuning VE and correcting for *small* mistakes. Of course if your injector/cam/trigger/sensor data is just wrong (or for a GTT which is not a GT) then you will get impossible reactions to things. I am sure you know this already but the reason people don't typically put haltechs (or any Aftermarket ECU) on GT's is because there's practically no real gains to be had - So this knowledge won't be commonplace.
    • Can someone tell me if the cracks seen in the rear sway bar bushings in these photo's is unacceptable from a roadworthy point of view?
    • Shouldn't need a "base map" for anything other than guidance to ignition tuning. You just need the engine capacity right, the injector size right, and something, almost anything, for a VE map. On an NA engine, fuelling is almost completely a function of load signal & rpm. It should run and drive with a completely flat fuel map. It will be too lean under load, but that's easily fixed. We used to tune all ECUs without any base map. There were no such things (until someone had tuned a near stock engine on one, and then they had a "base map".
    • What did you actually buy/how much did it cost? When I got mine in like.. 2017...? 2019? the aim was to run Torque for gauges via ODB2 and things like Track Addict/Laptimers/Dashcam/Reversecam/Spotify etc. Mine never broke, but I wonder if you've got the same needs (it sounds like it). Cause I liked the idea of being able to do anything with it. That said, yours also cost 3x the cost of what I spent so... food for thought.
    • For me there is a massive difference in manufacturer or big brand crippled android (Sony, Kenwood etc) vs the sort of thing I've installed here, which is basically just a tablet in DIN form factor with open Android, and the other model of course is mirroring - Android Auto/Carplay. I hate the locked down manufacturer and AA options where they decide what apps I'm allowed to install, including the Launcher but also importantly things like Ecutek (for this car) or Real Dash (Stagea) are not supported. Plus those crippled versions tend to be slower due to both overheads and lower spec hardware. On the other hand, when this breaks I'll likely be in trouble for support....but how is that different to owning an Infiniti anyway
