Officially a home owner
Suddenly I have an opinion that the current generation of first home buyers are all a pack of entitled and whinging layabouts who should suck it up about the ever increasing prices and stop buying smashed avocado
  • Like 5
Sheeeeeit - Congrats Adam!
  • Like 1
That r33 gtr will never be finished now
My last rental had ancient wine stashed under the house. There was 1 foot of water under the house from poor drainage. The snails ate the labels off the bottles. f**king old Italians... Noobs forever.
A small house in the south east on my income - 80% LVR / no LMI, 50% stamp duty
Small as in...no backyard. But when your fence is a giant gate with acres of park land behind it that you don't have to maintain...
  • Like 1
A friend of mine bought a two storey townhouse in Mt Waverley a year or two ago...the number 8...for 800k iirc. He put a bid in not expecting to win cause there were Chinese buyers present...nek minut
He is Singaporean though, so we still laugh that he probably looked like "that guy" on the day to everyone else
So a massive gate and massive sliding/folding glass doors across the whole back of the place?
It seems like a fine stage from which to show off your efforts in the gym, at least thats the first reason you would want it that comes to mind.
  • Like 3
small side garden I see to work on.
the empty lot next door is that part of the park or will some-one build on it?
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
