4 hours ago, Kinkstaah said:
I get under 200kms a tank on E85.
Yay me.
#autolyf
Lol f**k, and I thought filling up mine every 350km or so was a pain in the ass. that would mean you'd be looking for a servo after 150kms
I pretty much consider a full tank of gas for any kind of spirited drive - I.e going to Healseville, Mt Donna Buang, Buxton, etc are all $80 affairs for the round trip.
98 gets me maybe 20-30 more kms from the tank. It isn't so bad as my drive to work is 5km, if I had to commute an hour each way every day then oh boy. $
Reminds me of a street machine mag I was reading during lunch the other week, old man with his yellow classic Monaro with 900hp that runs 9's saying he drives it every weekend and is a great cruiser.
Runs bicycle wheels are the front and a 2 speed powerglide. Have fun with that buddy. Would make Gregs fuel economy look like a VW golf diesel.
She is back and powered by e85.
Relied on the stock fuel pump wiring to keep up but couldn't hold fuel pressure. Dyno tune aborted but car is driveable for the 1000km run-in. Time to rack up the km's for the eflex tune.
  • Like 3
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
