18 minutes ago, blah_blah said:
das it leigh das it
Welcome back to the import scene
#blue evo v sti rivals
Only took me 6 years :P I've actually spent more time in the Aussie cars than Imports :O
Mustang Resources gets a shitty result from first ruby bids... Trading halt yesterday, 60% drop today
Was hoping to get it and sell on the bounce but seemed to have missed the boat :(
Bitcoin exploding towards the 18th of November... the next fork.
In the mean time, other altcoins are dropping as everyone pooling money to bitcoin. Interesting times ahead.
#cryptolinesaustralia
  • Like 1
ive been keeping an eye on things, but got a Coinbase account today and limited to $300 for the first week.
so like 0.00000000000033 of a coin.
Its complicated shit, so starting with Coinbase is like the Paypal. me and 1.5million others every month.
I know I'm old now because
After oversowing the front lawns with seed
I was watering them and some kid rode over the grass with his f**king unnecessary mountain bike, leaving a deep line across it
And all I could think was "f**king kids, get off my lawn"
  • Like 2
My lawnmower is a freebie. It's a piece of shit, but I manage to resurrect it from the dead most weekends. Mower place told me to throw it in the bin, so I bought a 70c head gasket and solved the compression issues.... They told me to throw my whipper snipper in the bin too, but I just replaced the whipper head and it's going strong 2 years later.
2stroke4lyf
I enjoy my lawn work, not just relaxing but satisfying bringing it back from THE DEAD. Amazing what difference a little extra makes and you get to one up your neighbours.
That was about a month ago^. Currently looking heaps thicker and lush. Tempted to tear it all up and start again with level soil.
Just a shame there is a park next door so people walk across the lawn instead of the footpath; probably why it got so f**ked up in the first place.
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
