People like mudflaps the same reason they like flared guards, the same reason they like vortex generators, the same reason people like wangs and motorsport-looking fitment,
Function IS form.
Whether people need it or use it is another story
88e is still alive?
inb4 SAU 2038 still talking about 88e announcements @3c [emoji14]
That will happen.
Because this thread hasn’t been renamed to 88e thread [emoji14]
Metec results are out
19th overall, not bad.
As suspected went well on the skid pan (3rd I think?) but not as well on the open courses not wanting to bin it :D
Edited by UNR33L
yeah the Pan results were the last I entered,
you were not looking good prior to that...
that said Pat WTF....the only time out of the bottom 10 off the pan was when I said I wanted some Neo Limiter skids...
Ended up higher than all the mates I knew that had entered, so it's something I guess
That being said having a dedicated track car would make you so much more competitive not really caring if you run wide etc.
Good day overall, apart from the waiting :D
Haha 370kw with tyres I planned for skidpan use-only and not a whole day of wet track sprints [emoji29]
After I went sliding onto the grass, I saved the fun for the skid pan
11 hours ago, Rekin said:
Haha 370kw with tyres I planned for skidpan use-only and not a whole day of wet track sprints emoji29.png
something something i told you something something tyres
    • Ahhh, I need the whole head unit. I definitely needed to roll back through and review your setup, ha ha! Neat setup they have going on. I just need a full double din head unit. But I want good and responsive. I might have to review what the likes of pioneer have out these days.
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
