People like mudflaps the same reason they like flared guards, the same reason they like vortex generators, the same reason people like wangs and motorsport-looking fitment,
Function IS form.
Whether people need it or use it is another story
88e is still alive?
inb4 SAU 2038 still talking about 88e announcements @3c [emoji14]
That will happen.
Because this thread hasn’t been renamed to 88e thread [emoji14]
Metec results are out
19th overall, not bad.
As suspected went well on the skid pan (3rd I think?) but not as well on the open courses not wanting to bin it :D
Edited by UNR33L
yeah the Pan results were the last I entered,
you were not looking good prior to that...
that said Pat WTF....the only time out of the bottom 10 off the pan was when I said I wanted some Neo Limiter skids...
Ended up higher than all the mates I knew that had entered, so it's something I guess
That being said having a dedicated track car would make you so much more competitive not really caring if you run wide etc.
Good day overall, apart from the waiting :D
Haha 370kw with tyres I planned for skidpan use-only and not a whole day of wet track sprints [emoji29]
After I went sliding onto the grass, I saved the fun for the skid pan
11 hours ago, Rekin said:
Haha 370kw with tyres I planned for skidpan use-only and not a whole day of wet track sprints emoji29.png
something something i told you something something tyres
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
