11 hours ago, Leroy Peterson said:
So birds, you never replaced your old bike after it got pinched?
Sell all your gear n stuff?
Nah I replaced it with the GTR which is much less stealable in its current, non super saiyan form.
Still have gear for occasional test rides.
Beamer walked away after neck and neck, like he found another gear or vvti or something. Seems they are modifying the latest turbo ones for some decent power. Only had two exhaust tips on the left instead of one each side, which is the 2 litre turbo model...sleeper ass car ?
https://www.sau.com.au/forums/applications/tapatalk/index.php?/topic/474600-2001-Nissan-200sx-Spec-R
Lol this ad
Edit: just checked carsales, hory sheet. Try to find an ad not made by a spaz, lying through their teeth, with genuine kms.
Also the prices.... Fark dat.
Alex is no longer talking down to us
Leigh doesnt have a falcon
Burds hasnt had his car broken into in a few months
I realised Pulsars are no longer the best cars under $10k now.
Odie too cool for us
Dezz doesnt need computer advice at the moment
Martin working from home mostly
So yeah, not sure what else this thread is good for now.
But even wasteland is dying down.
  • Like 1
Lol this is the only thread i check on here, isn't the forum slowly becoming less active anyway?
Went to the tuned meet yesterday.. holy shit there was a lot of cars, would of been a 1 hour + wait in the queue to drive in so I just parked outside. Never seen such a big meet.
Yeah i heard it was huge. I saw a thing for it a few days beforehand but just assumed it was just another crappy Tuned meet.
Sakura picnic is back in October, so that'll be good. Theres a Jap parts swap meet in croydon in september, hoping to get a group stall and flog off a bunch of shit.
Hot Import Nights in sydney is more about instagram models and breakdancing/bball 3v3 than actual cars (not even joking).
Which leaves WTAC and All Japan Day as the only decent shows in Aus at the moment.
Nissan Datsun day is a bit same samey.
Apparently 100mm organisers are doing a new event in Feb next year. Invite only allegedly. They want a VIP display so the gloria will get some efame, which will be cool.
  • Like 1
What is the new best car under 10k?
2009 Honda Jazz bro, did you even need to ask?
Just add HKS intake pipe and Mugen slimline weather shields, will decimate all (at carrying large amounts luggage and fit into small parking spaced)
was discussing that with a mate the other day, he wants a cheap car till the next 911 comes out...(one extreme to the other)
best we could agree on was a Liberty GT STI edition.
https://www.carsales.com.au/private/details/Subaru-Liberty-2006/SSE-AD-5372081/?Cr=0
  • Like 1
weren't they meant to have brembos?
looks decent enough though, FG XR6T are near on the 10k mark now too ❤️
Edited by UNR33L
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
