Vic Wasteland Thread - 15.0
Neoman1995 did the diodes to trick ecu code 44 and 46 work? With the diodes really need to.knowthanks in advance
Hello guys did anyone sort this issue Neoman1995 did respond if his voltage at certain pins tricked the ecu im havn the same problem need to no if it worked tricking the ecu
Woot! My diff is done! I just need to finish doing a wheel bearing while the exhaust and shaft is out of the way, pick it up and hopefully put it in next weekend!
