  • 3 weeks later...
Sold out of CPH today, they got bought some Canadian medicinal marijuana company...
So if 20% of my holdings are over 12 months old... does that mean I only pay tax on 80% of the profit, since those shares I've owned for less than 12 months?
So if my first buy is at a loss... I pay no tax?
Then second buy is all the profit and all the tax.
Yes. Or the first buy losses offsets the second buys taxes.
That's the way the accountant told me to do it, treat all buys as individual transactions (as they are) and sales take shares out of the earliest transaction until it's done then move on to the next oldest. If you do it that way the tax office has nothing to argue about you doing anything dodgy.
The CGT reduction is 50%, so you only pay half the tax on profits from any capital holdings over 12 months old. If that's 20% of your shares, then you can nominate ANY 20% of your shares in the company to apply the reduction.
As you haven't sold any of the shares you have realised a loss yet, so even if those older shares were sold at a loss, it's irrelevant. What matters here is your average purchase price and your average sell price - what is left over is your profit. 20% of that profit you could argue should only be taxed at half the rate, whilst the remaining 80% will be taxed at the full capital gains tax rate.
Litecoin surging... At break even point. Will probably pull out soon and re-enter later once it dips (and it will).
Got to try and remember how to use my ledgerwallet now... lol
Speaking of pulling out... What's a realistic budget for a wedding? Not looking at receptions at this point... So just venue, snacks/catering/seating, photos, flowers, celebrant etc.
Asking for a friend who is budgeting for the future.
Ignoring reception I would think it would cost circa:
pre marriage course 240
Veil 260
Dress 3610
Photographer 3600
wedding cars 1660
Church 800
invitations & stationary 1419.49
Florist 500
Her wedding band 2300
His wedding band 735
Get married at the registry - in and out in 20 minutes. Genuinely one of the better weddings I've been to. Your guests will love you for not making them stand/sit still for a couple hours and the bride has no excuse to be late.
Spend the rest of the money you saved on a reception at with a 9 course meal at Sake down the road in their private/basement function room/bar; walking distance so no transport required. Guests will also love you for this.
  • Like 1
a custom designed titanium with a gold inlay....
and to be married in a church you need to do a pre-wedding course, which I thought was a load of bollocks till I did it and had some good stuff.
Oh and lots of religious stuff.
My sister is doing the registry thing later this year and a big reception. I for one, do appreciate it not sucking up an entire weekend.
Personally, itd be nice to get it all over and done with in one afternoon. Engagement party to merge and meet families etc, that's about it. I know friends want to be involved but isn't it just easier to include a small handful and keep it low key?
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
