Engagement party was the easiest thing.
parents back yard, grabbed some booze and we catered ourselves,
we hit up one of the wineries a couple months b4 for end of bin specials, raided my duty free booze and a few slabs of beers sorted
7 hours ago, emts said:
a custom designed titanium with a gold inlay....
and to be married in a church you need to do a pre-wedding course, which I thought was a load of bollocks till I did it and had some good stuff.
Oh and lots of religious stuff.
Fancy ring, fair enough.
Who teaches pre-wedding course? And do they hold TAE40116 Training and Assessment qualification?
Good stuff like saying "try not to get divorced"?
TLX going parabolic. Thanks for the tip Leigh.
Hard to know where this share is going... Big price swings on little volume is a red flag, but it's only year 1. I'm 50% hold, 50% cash out....
  • Like 1
Was wondering if you still had them :)
Yeah they're going pretty good, who knows what the future holds.
How much should someone trust your banks online mortgage calculator?
I was f**king around with commbank's one and it says they'll only give me slightly more than my total assets worth (savings, shares, cash, cars) even though my expenses are only 65% of my base pay (after tax).
I know they can't use irregular overtime and irregular non-taxable income to work out loans, but when it makes up an average of 30% of someones income over a few years, they can't just ignore it?
I'm not looking for a mortgage, or even sure if I want one, but just curious.
when I first talked to the bank they offered way more than the calculator after getting details.
(we actually wanted less than the calculator offered anyhow)
when we eventually went through a mortgage broker they offered even more.
Can def see how people get into trouble with how much they offer.
Where as I worked out what repayments I was comfortable with and worked back from that.
so my theory is banks will give you just about anything so long as the property is worth 20% more than the loan, as worst case is they will foreclose and get their profit anyhow. best case is more profit as you borrowed too much and are living off black and gold tuna.
#inb4hatishtellsthetruth
16 hours ago, dezz said:
Banks aren't giving out money like they used to.
Pretty sure they won't factor in shares unless you sell either as they're potentially worth $0 the next day, or in the case of 88e, definitely.
is this due to you buying more 88e?
Leroy do you still own any 88E?
Yeah it's like 30% of my portfolio.
Will sell most when I hit green. Will keep some because hodl
Speaking of hodl and parabolic, Ive been back in the green on Bitcoin the last few days. Obviously everything else except Litecoin has tanked.
Now not really sure what to do... First big whale sell off hit this morning. But it gains momentum just so quickly
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
