Engagement party was the easiest thing.
parents back yard, grabbed some booze and we catered ourselves,
we hit up one of the wineries a couple months b4 for end of bin specials, raided my duty free booze and a few slabs of beers sorted
7 hours ago, emts said:
a custom designed titanium with a gold inlay....
and to be married in a church you need to do a pre-wedding course, which I thought was a load of bollocks till I did it and had some good stuff.
Oh and lots of religious stuff.
Fancy ring, fair enough.
Who teaches pre-wedding course? And do they hold TAE40116 Training and Assessment qualification?
Good stuff like saying "try not to get divorced"?
TLX going parabolic. Thanks for the tip Leigh.
Hard to know where this share is going... Big price swings on little volume is a red flag, but it's only year 1. I'm 50% hold, 50% cash out....
  • Like 1
Was wondering if you still had them :)
Yeah they're going pretty good, who knows what the future holds.
How much should someone trust your banks online mortgage calculator?
I was f**king around with commbank's one and it says they'll only give me slightly more than my total assets worth (savings, shares, cash, cars) even though my expenses are only 65% of my base pay (after tax).
I know they can't use irregular overtime and irregular non-taxable income to work out loans, but when it makes up an average of 30% of someones income over a few years, they can't just ignore it?
I'm not looking for a mortgage, or even sure if I want one, but just curious.
when I first talked to the bank they offered way more than the calculator after getting details.
(we actually wanted less than the calculator offered anyhow)
when we eventually went through a mortgage broker they offered even more.
Can def see how people get into trouble with how much they offer.
Where as I worked out what repayments I was comfortable with and worked back from that.
so my theory is banks will give you just about anything so long as the property is worth 20% more than the loan, as worst case is they will foreclose and get their profit anyhow. best case is more profit as you borrowed too much and are living off black and gold tuna.
#inb4hatishtellsthetruth
16 hours ago, dezz said:
Banks aren't giving out money like they used to.
Pretty sure they won't factor in shares unless you sell either as they're potentially worth $0 the next day, or in the case of 88e, definitely.
is this due to you buying more 88e?
Leroy do you still own any 88E?
Yeah it's like 30% of my portfolio.
Will sell most when I hit green. Will keep some because hodl
Speaking of hodl and parabolic, Ive been back in the green on Bitcoin the last few days. Obviously everything else except Litecoin has tanked.
Now not really sure what to do... First big whale sell off hit this morning. But it gains momentum just so quickly
    • OK, Step 3, if you need to remove the valve body, either to replace it, the TCM, or to do a more complete drain.  First, you need to disconnect the TCM input wires, they are about half way up the transmission on the drivers side. One plug and the wires are out of the way, but there is also a spring clip that stops the socket from sliding back into the transmission. On my car the spring clip was easy to get, but the socket was really stuck in the o-ring of the transmission housing and took some.....persuasion. You can see both the plug to remove (first) and the spring clip (second) in this pic Incidentally, right next to the plug, you can see where the casting has allowance for a dispstick/filler which Nissan decided not to provide. there is a cap held on with a 6mm head bolt that you can remove to overfill it (AMS recommend a 1.5l overfill). Final step before the big mess, remove the speed sensor that is clipped to the valve body at the rear of the box.  Then removal of the Valve Body. For this the USDM Q50 workshop manual has a critical diagram: There are a billion bolts visible. Almost all of them do not need to be removed, just the 14 shown on the diagram. Even so, I both removed one extra, and didn't check which length bolt came from which location (more on that later....). Again it is worth undoing the 4 corners first, but leaving them a couple of turns in to hold the unit up....gravity is not your friend here and trans oil will be going everywhere. Once the corners are loose but still in remove all the other 10 bolts, then hold the valve body up with 1 hand while removing the final 4. Then, everything just comes free easily, or like in my case you start swearing because that plug is stuck in the casing. Done, the valve body and TCM are out
    • OK, so if you are either going for the bigger fluid change or are changing the valve body which includes the Transmission Control Module (TCM), first you should have both a new gasket 31397-1XJ0A and a torque wrench that can work down to 8Nm (very low, probably a 1/4 drive one). You can probably get by without either, but I really didn't want to pull it all apart together due to a leak. First, you now need that big oil pan. The transmission pan is 450 long x 350 wide, and it will probably leak on all sides, so get ready for a mess. There are 24x 6mm headed bolts holding the pan on. I undid the 2 rear corners, then screwed those bolts back in a couple of turns to let the pan go low at that end, then removed all the middle bolts on each side. Then, undo the front corner bolts slowly while holding the pan up, and 80% of the fluid will head out the rear. From there, remove the remaining bolts and the pan is off. You can see it is still dripping oil absolutely everywhere...it dripped all night.... I got another couple of litres when I removed the pan, and then another few when I removed the valve body - all up another 4l on top of the 3 already dropped in step 1.
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
