Vic Wasteland Thread - 15.0
R31Nismoid
 Share
1 hour ago, Leroy Peterson said:
Alexs.
Shoulda been able to buy 8 properties by now. If I followed his 10 step program to a million cash before 30.
haha.
speaking of, 30 in two weeks - not a millionaire :(
feeling old af
if I'm 30, Hamish must be like 65 now
Edited by UNR33L
  • Like 1
12 hours ago, Leroy Peterson said:
Yeah it's like 30% of my portfolio.
Will sell most when I hit green. Will keep some because hodl
Speaking of hodl and parabolic, Ive been back in the green on Bitcoin the last few days. Obviously everything else except Litecoin has tanked.
Now not really sure what to do... First big whale sell off hit this morning. But it gains momentum just so quickly
I'm interested to see what comes of the farm out announcements. They're tight lipped about who and incremental updates for every signature they get on each piece of paper is just annoying, but shouldn't be too long now that they announce the terms of the farmout and that should give  a bit of a short term lift. Might be your opportunity to exit before any other big projects.
Awful as it is, US conflict with Iran is the best thing for US oil share prices...
Did you dump your bit coin before it popped?
Nup, I'm still in the green though. And it's still up for the week.
I'm not concerned about crypto, lots of wheels spinning behind closed doors. Shit will change the world one way or the other, but whether current crypto will be worth anything, who knows.
Basically we don't give a shit about assets with home lending. You could have $5 or $5mil to your name and it won't affect the outcome. Assessment is made based on taxable recurring income as this is what we need to demonstrate to APRA.
If you own a business it's slightly different in that we use EBITDA less tax... So you pick up depreciation and interest expensed but still essentially the same thing.
  • Like 1
Started to look at houses to buy with the other half, the realization is real that you need to spend like 800k to get something remotely decent around the Wantirna / Bayswater / Rowville / Scoresby areas.
650-700 will get you a very average (to put it politely) house in Boronia scattered with cats during the open for inspection LOL
I guess not much has changed since I got my little Clayton unit back in 2014
Waiting for the banks to tell us to f**k off anyway though. ?
Edited by UNR33L
Leigh drive 5-10 minutes further than Rowville and look for a large sized older joint or decent sized new joint in Hallam/Endeavour or Narre for the same money.
Fountain Gate is going to do to Narre what Eastland did for Ringwood...already happening.
  • Like 1
Yeah considering it, Furntree Gully seems okay for the $ too
Hard to find a place that ticks most of the boxes in general too, still early days tho.
Also amazing how fast you can save $$ when living back with the parents, even though its really annoying.
Edited by UNR33L
Don't know them feels, mine charged rent at basically market rate.
  • Like 1
This.
Think I would struggle to share a multi room air bnb with my mum for one night, let alone move back "home" ("home" has changed twice since I moved out)
 Share
    • Opened up the cluster to inspect the gauge itself for signs of damage and it looks good. Got curious since that needle doesn't go back to a "neutral" position by itself (it stays in the same position when ignition is off. so I manually moved it to 1/2. Connected it back, turned on the ignition and the needle started moving up! Not sure what's up with that but before that the needle was way down below empty like fully south west. There's always a chance that the needle moved slightly the first time I tried and I didn't notice because of how slowly it moves and how far it was from the markings. I don't know if the current needle position is accurate so I'll fill it up and see where that brings it. I guess I'll try to adjust it manually if it doesn't get to F. Looks like the needle position is relative and not absolute? Thanks all for your help and patience!
    • You're confusing two different responders and more than one issue. The stock Neo ECU boost sensor is used by the ECU for protection purposes. It is essentially only an overboost sensor. It is not used for determining engine load for fuelling or ignition purposes. That task falls solely to the AFM. Any aftermarket ECU that either has an onboard MAP sensor or a plug in one, will use the MAP sensor as the primary load sensor. Or I should perhaps say "can", rather than "will", because some of them have the option of using other primary load sensors. That MAP sensor is not for the same function as the stock Neo boost sensor. The reason I recommended against a plug and play ECU is that they are intended to run a particular engine and usually in the car that the particular engine came in. So, if you have a transplanted engine in a different car, with some parts of the original missing (such as the boost sensor, for example) and therefore likely non-standardness of the loom and its insertion into the car's loom, then it is very likely that you will run into the same problems with needing to fix up wiring to make it work that you would with the stock ECU. And, if doing so for the stock ECU is enough of an obstacle that you start considering a standalone plugin as a solution, it should become clear that the plugin is quite possibly not the solution you'd hope it to be. It would just lead to more of the same type of problem solving work to get it going. In the above paragraph and in my earlier post, the lack of the boost sensor is not critical. It was just used as an example of something that we knew you did not have right, such that the stock ECU would not work. I took that as an indicator of a reasonable probability that there were other related problems hiding there.
    • I can think of two places in my city of <1.5million population that specialise in automotive instrument repairs.Unless you're out in the wilds of Quebec, you have 3 major Canadian and 3 major US cities within the same distance as the single nearest city to mine. Surely there is somewhere you could send it.
    • I never cared for twins but whenever these conversations came up, I always presumed the higher number represented a larger turbo. Learn something new everyday.
    • Interesting, I've never seen a failure like that before but with the age of these cars and the general questionable-ness of all kinds of parts these days you can't rule anything out I suppose. Boost leak testing the boost control system would've revealed this though.
