i know Renault always had a Clio following, but its like Renault is getting the fun models while Nissan is just... shit now.
Even the Q50/Q60 red looks painfully average, and very outdated in terms of infotainment. Can't imagine the VR30 twin turbo AWD being fun or cheap for maintenance.
because 'merica.
nissan has been so focused on the USA market for past 8+ years and they don;t buy small and fun.
Quantity over quality.
where as Renault is not even sold in USA they are focused on EU markets where small and peppy is everything.
https://www.whichcar.com.au/reviews/2020-renault-megane-rs-trophy-r-first-drive-performance-review
"The result is a car that on a circuit, with height lowered and dampers set to medium-rare, feels every inch as good and connected as a Porsche 911 GT3 RS, just front-wheel drive and less accelerative. There’s equivalent feel, finesse, grip and loads of traction."
And the truth is the rest of the RS lines are basically these style cars with full interiors, at least the clio RS variants and the Meg 225, 250 et al.
At least I'm gonna be 100% certain I will be like "shit, wish I didnt sell that" when I inevitably sell mine because 1 car lyf.
They're just so different when driven in anger compared to the staple of cool cars nowadays, i.e Golf GTI/Golf R.
That said the Cooper S is pretty cool too, but not quite the same thing, Renaults just got beaten to the ground much harder with depreciation lol.
Similar feels with my STI,  driven in anger its amazing, on track through the corner makes me her bitch and says back "is that all you got?"
Also since I put MCA Reds on I thought it wouldn't make much difference, thinking stock STI suspension would be pretty good - boy I was wrong! thing is like a gokart after MCA reds.
Trying to buy a house, got conditional approval but lender taking ages to give us formal approval and might miss contract end date, conveyancer asked for 1 week extension but owner declined - pretty frustrating!
Basically not budging on 2 weeks finance so we have until tomorrow. Lender business manager cant escalate because its 'within SLA' and on the pile of final stage approvals.
Edited by UNR33L
Yeah the bank was the worst part of our process as well.
I'd come to them do you ahve everything, yes we all good.
3 days later whilst I'm in an airport, oh can you go and get "XYZ that has to be done in person" for us.
Multiple Fkn times.
they do this day in day out, give a bloody check list and I could have it all for you in 2 days. and have machine learning  take care of the risk side as it will be faster and more accurate.
  • Like 1
Still got it, renting it out
Rent needs to go up a bit tho, everyone tells me too cheap (380 / week atm)
Prob could get 400 fairly easily but i'll go 390 at end of the year
I did draw 70k out of it to help with the new place though, used the equity can draw upto 80% of value
Edited by UNR33L
  • 3 weeks later...
51 minutes ago, Leroy Peterson said:
Ay-ay-ron popped into my news feed today... What cars has he been driving?
I kept out of the loop since the yellow Evo was sold...
A car.
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
