Going 29 would push the pistons over 86.5mm no?, wouldn't this reduce the reliability (thickness of walls)?
I also had a read of nitto's website, they do something interesting with the rod design to make the entire system more reliable, but cant tell if this is true.
86.5 is fine, can even go 87
My 2.9 doesn't actually make it 2.9.. It's still 2.8xx
In saying that even the jap 2.8s are not truly 2.8 .. They're stil 2.7xx
Which one would you choose, there are three?
Step 0 has the most response but lowest rev limit, not sure about 2 or 3.
How can different rotating assembly with the same capacity offer more or less "response"? The turbo(s) only know say 2770 cc worth of air pushing them, not that it has an I beam or H beam rod.
Think he's talking about weight
Yes sorry, I think Joey is right.
I was going off what was on their website so didn't clarify.
I see that this post is being ignored by everyone, as it should.
Not everyone :whistling: , some of us are desperate , so maybe if he/she did not want to kiss and definately no tounge, it could be a goer :yes::no::yes::wub:
Do you realize that Cutty has not been on HIS own thread since page 12 , post 221 and only 3 times since page 7.You blokes may have forgotten that he would love to go from 1000 to 9000rpm ASAP ( Yummy me too) and not from 5000 or 6000rpm to 9000rpm, maybe he is my long lost Son :woot:
Cutty has probably killed himself after reading our dumb arse posts, "I like them" as it gets boring if you know shit all about motors, technical shit, etc, Pics are good, so I am going to tell him something if he is still alive and kicking, some home truths as "I" believe them to be.. I find it hard to believe you can get a 26 to be as good as a 28 to a 32 as a DD if you want go from idle.
As a DD/ street car Cutty, you will be happier with a stroker in your Skyline, you say you want response ASAP as a DD , then, the bigger stroker the better to get these heavy low CCs cars going :yes:
To me with the extra CCs they are more linear and I believe safer on the road than a peaky R that kicks in hard. As you apply the thottle you can feel the car react more smoothly on corners and at least 1 or 2 gears higher. I do have an excellent drive line to help put the power down, no spinning wheels, just goes :yes:
I have no problem with other blokes preferences to how they want their cars to go , hope it works for them, but response is sort of like a swear word with "some" blokes on SAU, the only words I can think of to use instead of response is , Zoom , jump, leap, and fast! but 5 letters, quick, swift, rapid, brisk, hasty, nippy,smart, fleet, zzzzzzzzzzz whoops dozed off, time to top up :yes:
The only mod difference with the Dynos were , the cams went from 260 9.15 Poncam B to 260 10.8 ,, 6boost , 4" dump( same 3.5" exhaust) and of course the 3.2 stroker. When the 26 was first tuned with the new mods there were NO problems with the 3" dump.
But the 3.2 @ 437kw is 92 kw more @22psi than the 26s 345kw @24psi , that is a lot on 98 pump .
By the way , my daughters sleeping over tonight, so the old bloke has been out to play, hic hic :special:
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
