They are marketed as road and track but warranted only for road.
The best answer to this is either Dixcel or Project Mu.
And only warranted for 12 months,
Agree that they should be notified for engineering/quality control improvements if possible, saying that would make a pretty cool clock.
Thanks for all the replies. I'm dealing with DBA on the matter now and will let you guys know the outcome after they digest the info which has been requested.
I'm not expecting a replacement set or anything like that from DBA. I'd rather that they can find out what the issue is and tell me if it's the way I drove, a bad batch, or something else so that it can be rectified and doesn't happen to anyone else.
I was lucky that nobody was in front of me at the time who was also in the braking zone, and also lucky that there was heaps of space for me to run off into. I carry a spare set of rotors when tracking so was able to also swap them out pretty easily and drive home.
DBA have form with this for quite a while http://www.sau.com.au/forums/topic/186532-are-you-cracking-dba-rotors/
I spoke with them at the SAU NSW tech night, and they indicated that the metallurgy is strictly specified to give the right balance (for them) of a number of properties. To oversimplfy, you could consider the composition to be either long wear life (hard & brittle) selection, or a short life (soft & tough). IMO DBAs are too far down the hard/brittle end of the spectrum for track use and they shouldn't market their rotors for track.
The cheap arse RDA and D2/G4 etc rotors dont seem to have the same issue.
To the two points I've highlighted in red;
I did a factory tour last year with Members of SAU NSW for one of our most excellent Tech Arvo's organised by the Club Execs.
1; According to DBA; ALL 4000 Series and 5000 Series are cast in a proprietary grade of cast iron in a foundry based in Sydney. This is to guarantee the quality & consistency of their flagship product.
2; In the standard R33 GTS-t rotor size; there is no DBA 2 piece rotor available, so you are left with the 1 piece 4000 series T3 slotted rotor OP has quite reasonably decided to use for trackwork on what I'd assume is a modified STREET CAR, not a dedicated track car.
6 track days and 2000km of street use doesn't "seem" like a great deal of time, and the nature of the failure isn't something that you'd expect; and even DBA suggest that an amount of radial surface cracking in tracked rotors is perfectly normal, and to be expected (as you have also pointed out).
I'd definitely be approaching DBA, and asking for their guidance, and possible ways to move forward; they are (in my experience) excellent to deal with, and are very understanding of enthusiasts who use their product as it was designed.
Simply telling people that they have misused the product and that they should suck eggs is hardly helpful.
Cheers, Dale.
Well being a large account in the brake game i have some DBA senior management on my speed dial....so i made a quick call for clarification from higher up the food chain.
I was told "partially" what i posted over the phone, its all made here and O/S regardless of range...yep i initially thought maybe what i was told in the industry was wrong after what you posted and was preparing to apologize about my post.
So i thought id get some proof for you in writing, obviously having seen the plant, you may have "assumed" its all made here as the senior management pointed out to me.
So i emailed their team anonymously to get it in writing.....i have sent you a copy in your inbox of that whole email ping pong.
Certainly not all made in Australia, as you will see in your message i even tried to weed it down to the T3 or club spec or 2 piece range to say its 100% Australian made, apparently not so.
Not taking away from the brand, they make some good stuff, just clarifying what you didn't know or miss interpreted.
OR maybe senior management and sales team dont know the upper end all made here.
In case you want the china ones direct......
http://zhengnuogroup.en.made-in-china.com/product/NbVmiaIDXyYh/China-Excellent-Dba-Brake-Rotors-for-Australia-Market.html
  • Like 1
Hey Peter,
Read your email exchange; thanks for taking the time.
I guess it's like everything now; I'd like to say I'm surprised, but it's more like disappointment really.
Their "Premium product; locally made" quality assertion seems plausible, and as an enthusiast customer, you'd certainly want get behind them.
I took them at their word; perhaps I was being naive, but I did hope they would be honest, not just give us enthusiasts the standard sales guff.
  • Like 1
will this suit your needs? never had a problem with their stuff.
http://www.zshop.ca/parts/r33-performance-friction-front-dimpled-rotors-v-spec-brembo/
The PFC stuff did cross my mind, but it's just so damn expensive. I'm a budget racer so don't think I want to drop that sort of money on a set of rotors!
I'm considering just going for RDA blanks. Expansion and contraction should be better without the slots, they are cheap to run, and more surface area for the pad.
Did DBA get back to you about this?
I've send them photos of the rotor and my phone number which they requested, but that's all unfortunately.
well if you get extra coin, they are worth every coin.
Quick update:
A DBA rep came out to have a look at the rotors today, then took them away for further analysis, and will send me a new set of the same rotors even though the others were well past their warranty period and I have no proof of purchase.
He did say that they have never seen the rotor separate from the hub before, so they wanted to investigate it further internally. Overall happy with their customer service.
  • Like 6
That's the type of service I would hope for from a company like DBA.
It's a strange one, I'm sure tonnes of people are running them without issue.
I've ran mine through hillclimbs, tarmac rally, drifting, time attack events plus 20,000km of street driving too - no issues so far.
You are running a 324mm rotor with a spaced caliper?
That could likely to be a contributor to the cracking due to pad being in a different offset to what it is designed for. You can end up withba higher than ifeal temp differential across the rotor face
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
