They are marketed as road and track but warranted only for road.
The best answer to this is either Dixcel or Project Mu.
And only warranted for 12 months,
Agree that they should be notified for engineering/quality control improvements if possible, saying that would make a pretty cool clock.
Thanks for all the replies. I'm dealing with DBA on the matter now and will let you guys know the outcome after they digest the info which has been requested.
I'm not expecting a replacement set or anything like that from DBA. I'd rather that they can find out what the issue is and tell me if it's the way I drove, a bad batch, or something else so that it can be rectified and doesn't happen to anyone else.
I was lucky that nobody was in front of me at the time who was also in the braking zone, and also lucky that there was heaps of space for me to run off into. I carry a spare set of rotors when tracking so was able to also swap them out pretty easily and drive home.
DBA have form with this for quite a while http://www.sau.com.au/forums/topic/186532-are-you-cracking-dba-rotors/
I spoke with them at the SAU NSW tech night, and they indicated that the metallurgy is strictly specified to give the right balance (for them) of a number of properties. To oversimplfy, you could consider the composition to be either long wear life (hard & brittle) selection, or a short life (soft & tough). IMO DBAs are too far down the hard/brittle end of the spectrum for track use and they shouldn't market their rotors for track.
The cheap arse RDA and D2/G4 etc rotors dont seem to have the same issue.
To the two points I've highlighted in red;
I did a factory tour last year with Members of SAU NSW for one of our most excellent Tech Arvo's organised by the Club Execs.
1; According to DBA; ALL 4000 Series and 5000 Series are cast in a proprietary grade of cast iron in a foundry based in Sydney. This is to guarantee the quality & consistency of their flagship product.
2; In the standard R33 GTS-t rotor size; there is no DBA 2 piece rotor available, so you are left with the 1 piece 4000 series T3 slotted rotor OP has quite reasonably decided to use for trackwork on what I'd assume is a modified STREET CAR, not a dedicated track car.
6 track days and 2000km of street use doesn't "seem" like a great deal of time, and the nature of the failure isn't something that you'd expect; and even DBA suggest that an amount of radial surface cracking in tracked rotors is perfectly normal, and to be expected (as you have also pointed out).
I'd definitely be approaching DBA, and asking for their guidance, and possible ways to move forward; they are (in my experience) excellent to deal with, and are very understanding of enthusiasts who use their product as it was designed.
Simply telling people that they have misused the product and that they should suck eggs is hardly helpful.
Cheers, Dale.
Well being a large account in the brake game i have some DBA senior management on my speed dial....so i made a quick call for clarification from higher up the food chain.
I was told "partially" what i posted over the phone, its all made here and O/S regardless of range...yep i initially thought maybe what i was told in the industry was wrong after what you posted and was preparing to apologize about my post.
So i thought id get some proof for you in writing, obviously having seen the plant, you may have "assumed" its all made here as the senior management pointed out to me.
So i emailed their team anonymously to get it in writing.....i have sent you a copy in your inbox of that whole email ping pong.
Certainly not all made in Australia, as you will see in your message i even tried to weed it down to the T3 or club spec or 2 piece range to say its 100% Australian made, apparently not so.
Not taking away from the brand, they make some good stuff, just clarifying what you didn't know or miss interpreted.
OR maybe senior management and sales team dont know the upper end all made here.
In case you want the china ones direct......
http://zhengnuogroup.en.made-in-china.com/product/NbVmiaIDXyYh/China-Excellent-Dba-Brake-Rotors-for-Australia-Market.html
  • Like 1
Hey Peter,
Read your email exchange; thanks for taking the time.
I guess it's like everything now; I'd like to say I'm surprised, but it's more like disappointment really.
Their "Premium product; locally made" quality assertion seems plausible, and as an enthusiast customer, you'd certainly want get behind them.
I took them at their word; perhaps I was being naive, but I did hope they would be honest, not just give us enthusiasts the standard sales guff.
  • Like 1
will this suit your needs? never had a problem with their stuff.
http://www.zshop.ca/parts/r33-performance-friction-front-dimpled-rotors-v-spec-brembo/
The PFC stuff did cross my mind, but it's just so damn expensive. I'm a budget racer so don't think I want to drop that sort of money on a set of rotors!
I'm considering just going for RDA blanks. Expansion and contraction should be better without the slots, they are cheap to run, and more surface area for the pad.
Did DBA get back to you about this?
I've send them photos of the rotor and my phone number which they requested, but that's all unfortunately.
well if you get extra coin, they are worth every coin.
Quick update:
A DBA rep came out to have a look at the rotors today, then took them away for further analysis, and will send me a new set of the same rotors even though the others were well past their warranty period and I have no proof of purchase.
He did say that they have never seen the rotor separate from the hub before, so they wanted to investigate it further internally. Overall happy with their customer service.
  • Like 6
That's the type of service I would hope for from a company like DBA.
It's a strange one, I'm sure tonnes of people are running them without issue.
I've ran mine through hillclimbs, tarmac rally, drifting, time attack events plus 20,000km of street driving too - no issues so far.
You are running a 324mm rotor with a spaced caliper?
That could likely to be a contributor to the cracking due to pad being in a different offset to what it is designed for. You can end up withba higher than ifeal temp differential across the rotor face
    • Ok i will get those 310mm. I found one but on a different site. This is the description on those...is it ok? Technical parameters: - Axle: front. - Disc type: ventilated. - Number of holes: 5. - Disc diameter: 310mm. - Total height with center: 54mm. - Thickness (new/min.): 30/28mm. - Designed for brake calipers manufacturer: Sumitomo.
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
