That is easiest*, you do need the car up nice and high if you are doing it on stands to get the box to engine angle straight, otherwise you will have issues getting the shaft into the bush.
*opinions may vary.
*opinions may vary.
I'm very good at getting shaft into bush😂
  • Haha 1
19 hours ago, admS15 said:
Free motor, yes please. Please supply all parts (nitto only), machine, assemble and ship to me. 😂
Anyway, I've offered, not much more I can do to assist here. Hope it goes well.
Re box, box is a lot easier to move around than the engine IMO.
You will want 2 sets of hands regardless.
Personally, I'd put the engine in then bring the box to meet it as it's easier to maneuver.
If your engine crane setup has the balance bar, that can help immensely. Otherwise, use ratcheting straps, but remember they only go one way under load ;)
  • Like 1
2 hours ago, admS15 said:
Anyone see any issues with trying to get the replacement engine back in (when I get one) with gearbox in situ?  Is it doable or a major ball ache?
Personally I find it easier doing the motor/box in one go, aligning the motor to box is a cnut, however my delicate IT hands aren't good at ramming shafts into bushes like @Duncan
Just remember to take out the shifter from inside the car, rookie mistake on my part when I pulled out motor #1 with the box attached.
I'm trying to remove the least amount possible, there is obviously a shitload of stuff already off. I'll try offering bush to shaft first and see what happens. Hopefully ends up balls deep without much fuss.
Once you have the motor out, it's literally exhaust, unbolt centre of tail shaft from chassis (2 bolts) and then 4 bolts for shaft removal from diff, then 4 bolts for gearbox cross member, and the box will drop straight down.
Put the engine in the car, onto engine mounts loosely, leave engine attached to crank, but at rear of engine. Engine will tilt backward a bit.
With 2 people is easiest, offer box up to engine, do a few bolts up. Tilt the engine and box back to normal position, and put everything back together.
Putting engine and box I to the GTST is doable, but it's a lot of weight, up high, at an awkward angle. If you're not really careful, you're going to scratch the firewall, the tunnel, or the radiator support, or all 3.
Ask me how I know...
It is possible to also offer the motor to the gearbox with gearbox still in position, in this instance, I'd have engine mounts removed from engine to give you ease of sliding engine forwards/backwards to get your bush shafted, without smashing mounts to cross member while trying to line it all up.
However you do it, the absolute most important thing to do, is make 100% sure the clutch plate is align before tightening the pressure plate. I strongly recommend buying, borrowing, begging, or even stealing one to help yourself (or a spare gearbox input shaft). If clutch plate isn't aligned, no matter how much of a master you are, you'll look like a teenager trying to do it for the first time, possibly even asking yourself "is it in? is that it? Am I doing this right?"
Thanks for all the suggestions guys. Just need an engine now.
@MBS206 I have a clutch alignment tool for RB25 shafting.
Back in my P plate days, I had an RX4 coupe, blew many many gearboxes. Used to align the clutch with a cut down broomstick and eyeball. Got really good at it by about the 3rd time. Could do a gearbox swap in under an hour on that thing. Was awesome to work on, you could get inside the engine bay and stand next to the rotor motor Dorito.
  • Like 2
I have recently had to install a new clutch twice, and the box went on no worries both times, once in and once out of the car.
Both times without an aligning tool, mine is MIA, you really can just do it by eye. I was shocked at how easy it was without it.
Decided to take the box out to save on potential headfarks when reinstalling. Removal went smoothly, engine bay is ready for something new.
Finding an engine and the people you have to deal with is demoralising. Engine builder I saw the other day told me of an engine he saw at a local wrecker. I went and enquired at said wrecker, they get back to me today saying the engine has slight damage to a cam cover and throttle body. I get there to check it out, it's covered in like 5 years of dust, has been dropped or had something heavy dropped on top of it. Had a box with it too, cracked rear housing. I try turning it over, locked solid. Looks like something is jamming up the cam or could be bent from the impact it took. These idiots thought they could ask 3k for this thing, they don't even know if it was running when they got it. Unbelievable.
I'm trying to get it for scrap/rebuild value, so at least I have a block and hopefully good crank to work with. They're going to get their mechanic to pull some stuff off it tomorrow and see if it'll spin over and get back to me.
They also had an R34 na neo there, couldn't give me a price on it as they want to do research on it. I've got a feeling both these motors are gonna stay there for a long long time.
Other bloke who was selling na neo started being all evasive about organising a time to inspect and possibly make a deal. It's like these people don't want to sell. Kind of against the point of advertising something for sale.
Anyway, patience is going to be required here. This is going to take a while.
  • Like 2
  • Sad 1
6 hours ago, Dose Pipe Sutututu said:
Remember the days RB25s were like $1500 and actually were in decent condition?
Seems cheaper to put in a Barra.
I mean, this is literally one of the main reasons I did the swap back then....
haverb30blockpricesgoneupbysimilarvalues?
Gone are the days of cheap RB’s (in NZ anyway):
RB30 block from wrecker - $1000-1200
Complete engine from wrecker $6.5k (S2) to $8k (Neo)
I have my eye on a rebuilt Neo head and that’s $4k….
Barra would be much more economical.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
