28 minutes ago, No Crust Racing said:
Is it weird to get attached to things purely because they have lived a long life?
No. You can trust that thing. You can't necessarily trust the thing you buy from Bunnings.
9 minutes ago, admS15 said:
I would prefer cheap mineral oil for break in
I'm with you. It's kinda six of one, half dozen of the other. A good mineral diesel oil is actually a really good choice. High detergent, because diesel, no friction modifiers (because diesel engines are typically low speed engines). Perhaps that's less true now than it used to be though. All the high speed diesels in those shitty Mazda Karens and the like have probably meant changes for diesel oil formulation.
Interestingly, my petrol toyota engine specs the exact same oil as the diesel variant of that car, and guess what, those petrol engines are known to last forever and be clean as a whistle inside...
12 minutes ago, No Crust Racing said:
True of almost every aspect of cars really...
food for thought, brand new OEM performance cars don't use any form of break in oil either.
Not really comparable though?
I would expect a brand new performance engine to have been assembled in a very clean environment using high quality components and have most variables finally controlled. Heck, that'd probably include the knowing how much "material" the first oil fill will need "hold" from the break in process (if they are not being broken in on a dyno and having oil dumped immediately after).
Not quite the same as refreshing an engine that's had a spun bearing go through it or similar where you're re-using some parts that may or may not be hiding a plethora of debris.
Cost of engine rebuild? Many many thousands usually, $$ you save using plain mineral/something else oil vs break in oil for the first change? $50 - $100 if you're lucky? Break in oil is not exactly expensive.
Good mineral diesel oil ~ same cost as break in oil anyway. Would rather use the product specifically designed for the process personally with my extensive engine building experience (1).
Edited by No Crust Racing
17 minutes ago, No Crust Racing said:
.....I would expect a brand new performance engine to have been assembled in a very clean environment using high quality components and have most variables finally controlled. .....
I reckon not, performance or not they get slung together by a person that does the same tasks every 90 seconds for 8 hours.
I'll bet replacing an occasional engine in warranty is just an understood cost of doing business, most of the time they are lucky, sometimes they are not.
15 hours ago, Komdotkom said:
your Speedflow invoice
Could have bought another JDM shit box with it.
I feel dirty there are 3x Aeroflow fittings on my car, but I didn't put them on. Already have 1x Speedflow fitting to replace. 2x more are on the Plazmaman plenum on the underside, too hard basket lol.
I received a package the other day from @Komdotkom he said to me I hope your wife has a sense of humour (not sure her sense of humour would extend to this). A few days later this turned up.
Thankfully Im usually home before the wife so I could intercept the parcel. That particular day I got home and nothing had arrived yet. An hour later I heard something at the door so I opened up and there's my 8 year old daughter holding the above box, she hands it to me and says daddy you've got a parcel. Thank god she didn't read the return address or give it to my wife. Dragon lady crisis avoided, lol.
I don't have a pic on hand but inside the package was a RB head drain. Funny looking 3xl rectal probe that.
Going along with the theme of this build which is budget focused (tight arse), I found a couple of hydraulic fittings from work with sufficient ID to use on either end and some 19mm nitrile rubber hose. Working in a rubber factory has it's perks, occasionally. It's not pretty but will do the job.
  • Haha 5
I did mine in the BMRS crimp on stuff, the -16 fittings for the dry sump were quite expensive.
Just wait until the 18 " jellydonger arrives!
  • Like 1
Getting there
That's as far as I got before having to go do dad things.
I'm thinking on going with a .8mm washer to shim the oil pump relief valve. I could double up and run 1.6mm.  Just trying to keep the oil pressure same as before as the bearing clearances are bigger now. Do you guys reckon .8mm should be sufficient? Don't want to over do it.
I've kind of settled on the idea of .8mm but the pan hasn't been put on yet with sealant so can change it.
  • Like 2
On 03/12/2023 at 9:23 PM, Komdotkom said:
At least you know how to change it if it's not enough! It's a pity they aren't accessible without removing the sump (and the engine)
It's done now, the sump is on and buttoned up. Went with the .8mm,  engine builder suggested 1mm and shook his head when I said 2mm. Time will tell.
If it's not enough, can always run this stuff, lol
  • Like 1
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
