Will it sit the engine 10mm higher than std location?
Silvia guys report some issues with the SR20 sitting higher.
Anyone notice this on there R32 GTR or not really?
My concern is basically my new exhaust fitting exactly how it should.
Cheers.
Edited by mr skidz
https://www.sau.com.au/forums/topic/461455-nismo-engine-mounts-question/
yes, and yes. I can measure a nismo one if that helps but I noticed no difference
nah it's all good I'll soon find out lol.
I've already installed my engine with the Nismo mounts in just waiting for racepace twin 3 into 4 front pipe and since it merges to 4" I was just curious if it's going to fit after reading the Silvia guys comments.
Do you notice the difference with engine movement and gearbox as I fit all 3 of them.
Does it really help pulling gears at RPM
I have noticed absolutely no issue with the nismo mounts, nor before I had them. nor in my stagea which has standard mounts.
in the end I just went the nismo ones because they cost about the same, and why not try "upgraded"
I suspect that unless the current mounts are broken you won't notice a difference either
  • 6 years later...
I'm just wrapping up a CD009 install on an R32 and wanted to drop the front of my engine a tad to get a better driveshaft angle. I thought I'd chime in on this post with conclusive info as I have both new OEM and Nismo R32 mounts. 11220-02U03 vs 11220-RS585.
I'm confirming without a doubt that they are both the exact same height and both have the same "Squish" when installed. I ended up notching my engine mounts like the RB30 guys do. The height difference people see must just be the difference between settled old mounts and new fresh mounts.
Cheers.
Edited by TurboTapin
  • Like 1
On 19/08/2022 at 9:16 AM, GTSBoy said:
Correct. Nismo mounts are OEM mounts with Nismo tax.
They do come in a nicer box that looks great sitting on the shelf though.  Worth it for that.......
  • Haha 1
Same thing with the Nismo gearbox crossmember mount. I broke one and bought a Nismo one. They are IDENTICAL. I've now mixed it up with the other standard ones I have, as even the casting part number in the rubber is the same, so I don't know if I'm using a Nismo one or not now !
On 8/18/2022 at 8:16 PM, Piggaz said:
Then they end up like this.
Junk.
Went to the same place as the twins, the bin.
Lol always the exhaust side. I wrapped mine with gold reflective tape to see if it gives it a few extra years.
I noticed the Nismo engine mounts had the OEM part number in the rubber but I presumed this was due to Nissan using the same mold for both but with a harder rubber for the Nismo. I didn't see the need in creating two identical molds.
You gents think they are in fact identical parts ? It did cross my mind as a possibility...
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
