Hi all, i finally bought myself a R33 GTR and got it back down here to melbourne, now i really need to get it on a dyno and tuned properly, where would you guys recommend that's both fairly priced and knows their rb26's?
I'm also looking at getting the plastic surrounding the dash wrapped in leather or replaced for carbon fibre (it's a little scratched up and looks out of place compared to the rest of the car which is mint).
Any help would be appreciated!
https://www.sau.com.au/forums/topic/461512-best-place-for-tuning-melbourne/
Trent @ ChequeredTuning.
https://www.facebook.com/ChequeredTuning
He has years of experience with RB26's, we know a few happy customers of his.
Thats our Supercharged Honda S2000 on top of his page that he did for us the other day........drives beautifully and goes hard......
For GT-R's and RB26 here is the only place to go, they will also be able to fix any issues that arise while tuning and tell you if the car is on the money so to speak.
Racepace Motorsport
(03) 9762 9421
Also there is a sticky at the top of the forum with other tuning shops
  • Like 2
Thanks guys, i'm gonna go with racepace i think.
Does anyone know a place that can get plastic wrapped in carbon fibre (with the bath they do in the water to give it a layer) as my plastic around the dash is all scratched up and the only really shitty thing about the interior.
  • Like 1
Racepace Motorsport
(03) 9762 9421
+1 to racepace.
car gets better and better every time it goes there
Racepace for me as well.
RPM have looked after my car. Not sure if I have gotten worse and worse but my car is definitely getting better and better.
10 year long (and happy) customer of Racepace here.
Given you're usually the instigator, long as you don't, it should be fine? :D
Just making sure you know that Racepace is where to go for a tune :D
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
