thought i better update my time
SAU Nickname: sav man
Car Make and Model: 1989 BNR32 (GT-R)
Circuit Name: Symmonds Plains
Lap time: 1:02.94
Modifications
Engine: RB26
Power: 311rwkw
Suspension: some tenebe crap, HICAS completly removed and locked.
Tyres: Nexen 245/40R18
Brakes: Porsche 6 pot monoblock 355mm rotors Front. Rear standard with Hawk blue.
Body weight: stock - HICAS
also http://www.motorsportstas.com.au/Symmons_Plains.php?sm=4 some info on Symmonds
Edited by sav man
Well after what seems like an eternity to me I'm finally back and marked my return today at Phillip Island with a new PB of 1.47.24. Not too shabby given it is the 1st full track day I have got through in my car since Oct 05 and that the tyres I was on (toyo's) were definitely a good 1.5-2s slower than the bridgestones looking at how much Scotsman could get back on me through the sweepers and under brakes.
Racepace FTW! :whistling:
SAU Nickname: Wogboy
Car Make and Model: 2000 R34 GT-T
Circuit Name: Symmons Plains
Lap time: 1:07.75
Modifications
Engine: RB25DET stock turbo
Power: 225rwkw
Suspension: SK Bilstien group buy
Tyres: Falken RT somethings 235/45/17
Brakes: stock
Body weight: stock
SAU Nickname: AMEC
Car Make and Model: 300ZX Z32
Circuit Name: Wakefield Park
Lap time: 1:09.742 = 8th place on the list
Circuit Name: Queensland Raceway Sprint
Lap time: 0:57.56 = 2nd spot on the list
Modifications
Engine: VG30DETT
Power: 529 RWHP
Suspension: D2 coilovers
Tyres: F: 255/40/R17 R: 285/30/R18
Brakes: Stoptech
Body weight: 1403 kg
Phillip Island
Circuit Distance - 4.44km s
1. JagR33, R33 GTR - 1.46.36 sec
2. Aaron34, R34 GTR - 1:46.51 sec
3. Snowman, R34 GTR - 1:47.17 sec
4. Scotsman, R33 GTR - 1:47.79 sec
5 ferni, R33 GTR - 1.51.35 sec
6. BBGTR, R32 GTR - 1.51.76 sec
7. Roy, R32 GTST - 1.52.00 sec
8. Rowdyr32, R32 GTR - 1.52.23 sec
9. provo, R34 GTR - 1.53.97 sec
10. Ant97GTR, R33 GTR - 1.54.01 sec
Reference Lap Time:
- 1:45.28, GT Production Mazda RX-7
- 1:54.14, APCC Honda S2000 (Aus. Prod. Car Championship)
I was running 1.45s last year at an Alfa day. I can't remember the exact times though... Top of the list for me please...
Also, I ran 1.45.5 around Eastern Creek last year...
Damn you Aaron, was hoping you woudn't find this thread!!!! :P
But he's right, I did see a 1:45.8 from memory on Racetime at PI, before they deleted all previous event results....
SAU Nickname: archie01 (Archie)
Car Make and Model: R32 GTR
My times:
Calder 22/10/06 1:04.96
Sandown 10/06/07 1:23.58
Modifications
Engine: Cam Gears, single T04z
Power: 320rwkw Calder, 350rwkw Sandown
Tyres: 245/40/18" RE55's
Brakes: Alcon 6 pot fronts, standard rears, Braided Lines, Pads: F - DS3000, R - Endless.
Suspension: HICAS lock bar, Bilsteins, Whiteline f&r sway bars.
My times:
Modifications
I've seen a dyno sheet with 380+ kw. What happened to the extra 30 kw?
I remember as we came out of turn 4 and onto the back straight and you were in front of me, I wasn't able to reel you in but you weren't able to pull away either. So I'd say we're line ball on power but you have me everywhere else :D
I can see you in a 32.......and i can see myself in a 34....wanna swap? ;)
Its always satisfying when you can actually keep up with a car in a straight line...always so frustrating to be losing out in a straight line and having to fight to catch them up through the corners and under brakes....lol i can only do it for a few corners before overdirivng and losing even more time :D
Power: 350rwkw Sandown
F#$CK me, no wonder you blew me into the weeds on the straights..... :thumbsup:
I reckon by the 3rd flying lap, my car is down to about 280-285 rwkw given how hot it gets and how much timing is coming out and how much fuel is going in. I'm shooting 3 foot flames on decel when water temps are over 100deg C.
Cheers
Andrew
Cheers
Andrew
It's all factory issue for the ducting. The oil temps are not too bad as the oil cooler is in the front bumper and angled for maximum surface area. I've still got my air-con condensor so it blocks most of the radiator at the front.
With power comes heat, so unless I ditch the air-con there's not much I can do apart from doing some work at the bottom of the car to direct some air flow up into the hot part of the radiator.
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
