I was looking at this kit - https://rossperformanceparts.com/product/nissan-rb26-r33-r34-gtr-metal-jacket-harmonic-damper/
But read a number of reports about issues with PS belts being thrown.
A friend of mine works at Ross (came over when Omega bought them out) and claims they fixed an inherent design issue with the wrong offset on the pulley grooves when they came onboard.
I'm wondering if anyone has bought and used one of these in recent times and can report back on how you've found it?
They're mint now. Killer product and customer service is better than ever. I'm using their gear on my new build too.
So you have experience with it, or you're just talking up all the shit people gave you for free?
  • Like 1
I had two for the last ten years.
The early one still never through any belts, and the new one has the trigger wheel setup on it and it is all good too.
Great product, bit pricey for their trigger kit, but super well made.
People actually using them need to pipe up as it all feels hit and miss. I am holding off buying new OE as long as i can in case these things become a proven setup
As per the original post. Interested in people who have recently bought, not bought one years ago.
Just to clarify.
so you'd buy a part that proven to be f**ked because they "probably should" have fixed the problem now?
No.
I've already decided to leave the stock one.
Given there's clearly been some discussion on this here, I didnt think it would hurt to continue the thread if there was new info at hand.
Have you considered chilling out a bit?
My Ross damper was purchased in the pre Omega technical days. We recently pulled the engine to fit a bigger sump and open up some clearances only to find the balancer has chewed up the nose of the crank. Car has only done two dyno sessions and one light shakedown. Bearings looked good fortunately but we have some work to do to clean up the front of the crank.
The guys at Omega have the balancer for inspection at the moment. Have to say so far they've taken it seriously and aren't doing any of the finger pointing you normally expect in this sort of situation. Sounds like there have been a number of significant design improvements since Omega took over as well.
Whether I'm game to put it back onto the engine will depend on what happens next.
    • Pads for R32 GTS-t, R32 GT-R non V-Spec (Sumitomo), R33 GTS-t and R34 GT-t are all interchangeable. R34 GT uses a 2x piston caliper, hence it didn't fit.
    • Checked with amayama and nope, the full S2 manual set is not available anymore. Unsurprising, but still disappointing as the ? on availability gave a glimmer of hope.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
