Same here, Supercharge but Gold series across all our cars for availability, warranty, cost, configuration variations and performance life. If I can't get these then only Century.
Would love to run the Supercharge AGMs in the Nissans but they don't have the pencil posts and varied post positions available like the Gold series.
  • Like 1
2 hours ago, Dose Pipe Sutututu said:
Looking real nice!
I've moved away from Optima, they aren't of the same quality as they used to be!
I now run a SuperCharge battery (made for Stop/start applications and is an AGM battery - similar to an Optima), not to mention it's an Aussie brand with 3 year warranty.
https://www.supercharge.com.au/car-battery/supercharge-start-stop-car/?post_type=battery_type&p=173
All the in-laws' cars run their SuperCharge Gold range batteries, cheap and phenomenal warranty.
Cheers Johnny, shall look into it...
Cheers Benny
1 hour ago, Dose Pipe Sutututu said:
I bet you're excited!
Also I would recommend using some form of heat shielding OR wrap your dump/downpipe to prevent your O2 harness melting at the track.
when u say o2 are you referring to the wideband? same same...?!?
as that's just cable tied in that position now til we workout where it will enter the car...
excuse my dumbness, these are the sides of cars that I fail at...
Edited by mr_rbman
For the Wideband O2 sensor I just go through the existing egt floor bung and a Haltech O2 sensor wiring extension harness. Don't want to drill more holes in car than necessary.
  • Like 1
ye that was my initial thinking...
just so I wrap my head around this, both a narrow band and wide band sensor are essentially both just o2 sensors correct!?!
Yes
  • Thanks 1
33 minutes ago, BK said:
Wideband gives you an actual afr / lambda ratio, narrowband just signals whether it's richer or leaner than Lambda 1 / AFR 14.7:1.
Clear as now, cheers Ben
54 minutes ago, Dose Pipe Sutututu said:
Just delete the OEM narrowband junk, since you now have a modern ECU.
tis already gone, just the one wideband roughly 1000mm from turbo..
  • Like 1
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
