BEWARE.
USED THIS STUFF ON A CAMRY, (as per instructions) TOOK 4HRS, NEW BATTERY AND MOBILE MECHANIC TO GET STARTED, AFTER WARM UP CAR CHOKES AND DIES UPON ACCELERATION OR UNDER LOAD THEN HAS TROUBLE STARTING AGAIN, CAN'T WORK IT OUT.
ANY TIPS BESIDES PETROL AND A MATCH WOULD BE APPRECIATED, THANKS.
https://www.sau.com.au/forums/topic/464200-foaming-air-intake-cleaner/
I used Subaru upper engine cleaner in my Skyline a few times, it is hard to start if you dump too much into the engine at a time but it clears after running the car for a minute or so. Neighbours love the smoke show
As above, more information is needed or at the very least a better mechanic
Those cans just seem like an expensive way to make smoke. I know Subaru mechanics use them, but Subaru is the one selling them also. Seems like a better idea to not pump so much shit into the intake like exhaust gas recirc and oil vapour.
Nulon foaming air intake cleaner.
Followed exact instructions, well up to the first point of starting the engine. Have been told there could be deposits still in the system so take it for a thrash but if that is the case why does it run ok cold then when the engine warms up it chokes up under load.
What were you cleaning?
Shake the can before use, warm up the engine to normal operating temperature and for best results follow through each of the following steps.
1) Throttle plate cleaning:
Turn off engine and disconnect air intake duct from throttle body. Spray sparingly onto the throttle plate, wipe throttle body gently to remove excess liquid. Reconnect the air intake duct to the throttle body.
2) Inlet manifold cleaning:
Disconnect a vacuum hose from the inlet manifold and start the engine. With the engine running at fast idle, spray approximately half of the can through the vacuum line using the spray tube supplied. Then turn OFF the engine and leave to soak for 5 minutes.
If spark plugs are difficult to remove proceed to Step 4:
3) Piston crown cleaning:
While the engine is still turned off, remove all spark plugs. Spray a 2 second burst into each spark plug hole. Leave the engine to stand for 5 minutes. NOTE: Before reinstalling the spark plugs, cover up the spark plug holes with clean unused paper or cloth and crank the engine several times. Reinstall spark plugs.
4) Final cleaning:
Start the engine and disconnect a vacuum hose from the inlet manifold before spraying the rest of the can into the vacuum line while revving the engine. Reinstall the vacuum line and keep the engine running at fast idle until all the remaining cleaner is purged from the exhaust system.
This treatment is recommended for every scheduled service.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
