Hi All,
I installed a bigger radiator a few weeks ago in my R33 GTST because it was getting warm on the wet pan and I intend on going on a few track days. At the same time I put in a new genuine thermostat just as a precaution.
Since this has been done the car doesn't get anywhere near operating temperature (roughly 80 degrees) i.e. sits at 45-55 most of the time and gets to 70 on hot days. I just wanted confirmation that this is safe/normal/OK?
I spent some time looking for similar threads where someone upgraded the radiator and had low temps but didn't turn up anything helpful.
Thanks!
Edit: Forgot to mention that I'm getting these numbers off an aftermarket gauge using the GKTECH upper radiator adapter thingo. Factory gauge sits at 1/4 - 1/3 when I see 45-55 on the aftermarket gauge
Edited by kingtube69
Have you checked that the thermostat is working correctly by say letting the motor idle and feeling the hose to see when it opens? In fact at those temps (if correct) the thermostat should not open. I would be inclined to pull it out and see if it is stuck open. Or first get another view of your water temps by say putting a thermometer in the radiator filler or using a laser gun type thermometer.
Running that cold is not ideal.
  • Like 2
I'll run it today and check what the temps are like on the hoses - What am I looking for when checking the hoses exactly?
Get a new thermostat, they're so cheap any how... also could be an air pocket too
I'll grab a new one from Kudos in the coming days - I let it run for ages and ages and ages to bleed it so I thought I got it all out but maybe you're right.
Is there some special technique to getting it all bled properly? I have just been filling a cut bottle past the engine (sealed in the filler neck) and letting it run that way - Tried cracking the bleed valve and it didn't seem very effective. I have a hard time doing it at my house unfortunately so I normally have to go to a park or petrol station because my neighbours complain that it's too loud
Put your old thermostat back in and see what happens.
Didn't keep it unfortunately :(
to bleed my system i usually jack the car up pretty high eg so i can get under the car, then put a bottle in the neck and run the car.
no a hundred percent sure its necessary but i also have the heater fan full and hot.
Edited by MatthewT85
I wrap a couple of rags around the bleed valve and crack it open and closed a few times. The first time I tend to leave it open until I get flow, then its just open till it dribbles then off. Its not that hard. On a slope [on jack or ramps] would create cavities and not bleed properly I'd reckon [but don't know], I do mine on all four wheels.
I tried the coke bottle trick once but it didn't make any difference for me, just added another complexity I didn't need so haven't used it since.
If you start it up from cold and let it idle you just feel the top hose and when the thermostat opens it will suddenly get hotter. Of course this will not be the case if your thermostat is stuck open. In this case it will just slowly get warmer.
If your bleed valve does not work clean it out until it does work. Where exactly is you temp sensor for your aftermarket gauge? I cut the top hose in half and put an adapter in there.
  • Like 1
Those temps are very low.
Are you sure your temp sender is reading correctly?
Is it earthed properly etc?
Post a photo of the setup.
Its odd that both would read low (stock and aftermarket) I'll check the earth just in case
http://www.gktech.com/index.php/r33-silicone-radiator-hose-with-water-temp-fitting.html
This is what I'm using - The temps were always fine on the gauge till I went bigger radiator from what I remember
I normally do this with the neck and tape to seal it, never tried jacking it up though
I'll give this a try tonight (take it to the servo near my house) I'll let you know how it goes when I try it
The temp sensor is in the top hose (http://www.gktech.com/index.php/r33-silicone-radiator-hose-with-water-temp-fitting.html) last time I checked the hose it was a progressive warm up. I also don't recall the lower hose getting very hot but I'll double check
I'm possibly being a little over dramatic about this all maybe too cautious.
I took it down the road, cracked the bleeder and no air came out only coolant which I guess is a positive. Heater is still very hot (in the past if it had pockets it was cold and not hot). The top and bottom hoses eventually were hot but not so hot that I would burn my hands by holding them. Temp gauge also read 60 after a short drive home (1 minute max). Is this still something I should be worried about?
If it matters I also have a nismo radiator cap.
^^^what he said. Pull the thermostat out and if it's stuck open it's obviously dodgy. I hope it's not one of those Nismo low temp thermostats. If so bin it and get a stock one. The Nismo radiator cap "shouldn't" be a problem.
also make sure the little jiggly pin is pointing upwards, i.e. highest point in the housing.. if it is in the wrong way you'll have massive air pockets before the thermostat opens
I think the genuine part may have changed somewhere along the line. I tried a tridon one and a nismo one and then an OEM r34 one from kudos, and they all open at about 60C and thats pretty much my water temp.... Across 3 gauges.
Bit of an update on this - On the warmer days it gets close to 80 degrees but on cold days and nights it sits around 60. Plugged the laptop into the ECU today and it was reading out 72 degrees but the gauges were saying it was cooler than that (the aftermarket and stock). Is the temp difference to be expected on cold/hot days?
I'll get a new thermostat this week but I'm a bit annoyed if it's a dud because it's still new. I'll also test the old one anyway.
Jiggle pin is definitely at the top as per FSM (read it prior to changing it out)
Is it worth getting a new thermostat housing while I'm there as I've been seeing people talking about how fragile they are?
Thanks for your help all!
  • 1 month later...
Hi All,
Found the problem recently
DB92CE77-07C4-4876-8B52-8D7FBDD10CD4_zps
This happened because its difficult to put the housing on without bumping the thermostat out of the block (gasket maker grabs it and moves it) so I made up some studs and tried again
Thanks again for the help!
  • Like 2
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
