How much power do you want? Have you got a great suspension set up and good brakes?
For more power forget the cams and plenum and get E85 and turn up the boost (and get a top tune) and if that"s not enough upgrade your turbo.
Bigger cams will only move the power to the right on the graph. Yes there may be a tad more of it but you will loose a whole lot down low. Same goes for putting a different plenum on. So its a trade off. May be worth it, may not, depends on exactly what you want to do with the car.
Also note that if you upgrade to the wrong cams (generally anything massive) you will need to delete the VCT solenoid on the intake, which will also hurt low down torque and power. I think the HKS 256mm drop in does let you retain vct? (someone would have to confirm that) so that, or one tha tdoes, pretty much the only one you should realistically go with
I already have all that I'm using your turbo the atr45 externally gated.. I have a greedy Cooler and 3inch exhaust all the way through
I'm making 336rwkws on P98 fuel internally gated with exhaust dropped @ 22psi with the same turbo on stock cams, it is capable of making alot more then 300rwkws on P98 fuel with stock cams. There is a simple way of checking to see what you need. Take it back to the tuner to do a simple dyno run with exhaust dropped and do a pressure check across the cooler when its at full boost (check my thread). Also if you are running the JJR's 6 bolt Nissan front pipe, make sure the 6 bolt flange is die-grinded to suit factory dump pipe gasket.
If its showing its holding alot more boost that mades more power with dropped exhaust it means some thing in the exhaust is restrictive. Or if seeing 30psi before the cooler and 20psi after you will need a bigger cooler.
Having the bigger cams without the system been able to flow that extra bit of air, it will make absolutely no differences to peek power.
  • Like 1
fuuark it... might as well brag:
R33 Series 2 GTS-t with over 300000km (Edward Lee's Special Edition, dash says 157xxx)
  • Stock Motor with (most likely) 350000km, based on wear and tear of interior, bushing etc.
  • Stock cams
  • Stock valve springs
  • Stock valve seals
  • Stock head
  • Stock head gasket
  • Stock bottom end
  • Stock intake manifold
  • Stock exhaust manifold with havoc gate modification
I run camtech 272 9mm lift while retaining vct still, picked up about 45hp over stock cams and didnt shift the rpm too much as i kept the vct still...
but it isnt a cheap upgrade bit over 2k, prob find cheaper upgrades to gain 50hp..
Edited by methz
  • Stock cams
  • Stock valve seals
  • Stock head
  • Stock head gasket
  • Stock bottom end
Nice.
But he needs cams and a bigger turbo because of this:
^^^^ Much better daily
:yes::yes::yes::yes::yes::yes::yes::yes:
I was thinking 30 bottom end but I already have forged Pistons and stuff in the 25.. E85 more boost would be good but don't have e85 in Wollongong where I live.. So cams was the optiion and maybe a plenum.. I will do what you said stao and I will look into it! Thanks guys appreciate the feedback!
Another question my tuner said he doesn't want to run more then 20psi on my car because it's on 98 it's safe tuned can I run more?
Edited by sergi_dee
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
