Hi guys,
I have a series 1 r33 running spitfire coils, 1250cc injectors, walbro 460 fuel pump, gtx3076r and an Apexi fc.
The car DOESNT struggle on start up/Idle, but splutters and struggles to accelerate. After 15mins or so of driving, the car suddenly runs as normal and runs like a champ.
The problem all started within one day- I drove the car in the morning and it ran fine and then came back to it 2 hours after of parking and the problem started. Hasn't gotten worse or any better.
I have checked the spark plugs, they all look fine.
Is it a coilpack problem?
Ecu problem?
Sensor problem? As it runs like shit until normal engine temp.
Thanks a a million guys,
Any help is much appreciated.
  • Like 1
Sounds like maybe the cold start map is rooted?  Could be related to a sensor, I imagine a temp sensor.
I'm a f**king genius, I know.
Or I have no idea what the hell I'm talking about.  I'll let you decide.
Actually, i just found this - http://www.skylineowners.com/forum/21-tuning-technical-questions/217142-r33-gtst-starting-problems-help-please.html - it explains how to test the coolant temp sensor (wasn't the issue in his case).
  • Like 2
@Cowboy1600  Thanks man, I'll definitely consider what you suggested. I'm hoping that it isn't ECU related because I can't afford a tune!
Can anyone suggest any other possible causes? As I said it misfires pretty bad until the engine is warm (or after 15 or so mins of driving).
Thanks!
If the car ran fine then all of a sudden it started playing up, it isn't tune related. I'm with cowboy and suggesting a sensor. Probably coolant sensor, I believe there is a couple of them, not 100% sure. Do you have a hand controller for the power fc? If you do, you could check what the sensors are reading and if anything looks suspect.
There are two coolant sensors. the one with one wire goes to the gauge so won't be a factor. The one with two wires goes to the ecu. Try pulling the wires off . if it cold starts ok its definitely the sensor as without it the ecu will use a back up map but if its dodgy it will mess with things.
Thanks for the responses everyone. But a bit of an update; drove it again today and it misfired until completely warm, where it would then normally stop misfiring once warm, but today I also noticed a slight misfire whilst driving once the car was completely warm as well? The misfire when warm is irregular but seems to be on partial throttle, but full throttle it doesnt misfire :/ Still a coolant sensor problem possibly? Thoughts?
Edited by Azj
What's the point of sharing my thoughts if you just ignore them? Pull the wires off the sensor - 2 second job as above. If it doesn't make any difference its a two second job to put them back!!!
Could be a million reasons, the RB loves to keep you guessing. My experiences here, can be used as a bit of a checklist:
Anyway mine ended up being a busted CAS so it broke down past 4000rpm, yours sounds a little different.
UPDATE: So I pulled the coolant temp sensor out (to the ECU) and the car ran fine as it should with no misfiring. I put it back in and started the car again and seemed to rev/idle as normal as well with no misfire? Is it possible that the sensor just needed to be unplugged then plugged back in? And reset itself or something? Also, I pulled out the spark plugs and they are pretty black and look like they could do with replacement plugs.
@V28VX37  Thanks for your reply man- I'll have a look at your post if the problem persists.
Edited by Azj
Id pull the plug off the coolant temp sensor (ecu) and clean the contacts. Continue to drive and see if it is better. I would hazard a guess its more likely you have partially cleaned the contacts by removing and then re-installing the plug if the problem seems to have fixed itself. The ECU merely reacts to what the coolant sensor is telling it so there is no 're-setable' element to it
  • 1 month later...
Hey guys..just a bit of an update;
Ended up taking it back to my tuner and we diagnosed that an injector was faulty and replaced it. After this, the car seemed to run fine when you weren't hitting it hard, but when I did, 1st gear would break up badly (only 1st) and every other gear didnt feel like it was hitting full boost (I don't have a boost gauge). This all happened for about a week then the misfiring during sedate driving happened all of a sudden again.
Took it back and we diagnosed another faulty injector and replaced it. I got the car back today and it doesn't misfire when driving sedately, but 1st gear still breaks up hard and it doesn't feel like its hitting full boost in the other gears.
Is the next step replacing coilpacks? What else could be the root of the problem from other peoples experiences,
Thanks a million guys.
Hi Aaron
 just looked at the FSM page EN-139 states
Perform CONSULT active test mode
( Increasing "FUEL INJECTION" item) or
enrich mixture by disconnecting engine
temperature sensor connector and
inserting a 600 Ohm resistance after warming up the engine. )
Nissan suggest that insufficient fuel pressure could cause misfire on acceleration.
Has fuel pressure been checked? Have you an after market fuel pressure regulator or Stock? need to check that the regulator is working correctly also.
Lots of other checks that should be done on pages EN-139 - EN-142 before changing parts by guessing.
Michael.
Edited by msammut
  • 1 month later...
Sorry for the late reply but cheers for the response Michael- although the fuel pressure is fine on the FPR.
So now the car isn't missing as it was after replacing the coilpack loom.
Though the car is DEFINITELY  still down on power, and sometimes splutters briefly then pulls when you get on boost around 4500rpm and full throttle (again, the pull isn't as hard as what it used to be).
Tuner seems to think it's not the splitfire coilpacks after testing, all Injectors have been replaced, I've checked the coolant temp sensors, O2 sensors etc but yet no avail.
Can anyone suggest anything else?
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
