14 hours ago, Stephen_rx7 said:
Lol i don't know about that, i trust corolla parts more than nissan parts personally, that and they look better, do the job better, last longer and are a third of the price, seems a no brainer to me?
If i could toyotaise the engine internals i would haha
Its got a brand new n1 oil pump and a tomei baffle, dont know if that'll suffice for what I'm doing or not tho
Billet oil pump gears would be nice, its a long nose crank engine so touch wood no issues there
Sell it and buy another Toyota then?  Or ditch the AWD and throw a 2JZ in it.
I had an N1 oil pump.  I didn't limiter bash.  It died.  I'd flick it while you have the chance.  At the very least whack a set of billet gears in it for a bit of extra protection.
i have a 2jz jzx100 chaser so no need to push the gtr hard for power, just trying to make it as tough as possible without dropping 40k on an engine build, its a shame rbs arent spline drive from factory
there's no way of doing a 2jz swap without ruining the car so not an option
what power did you break your n1 pump with?
Edited by Stephen_rx7
Alrighty so i did abit of a test fit of the twin setup
New banjo bolts in everything
Interestingly the rb26 exhaust manifolds are slotted so are adjustable to a certain extent forward and back
Side on shot of the twins
Thats prerty much it for the hotside till a few more bits arrive, still need some new oil drain hoses, the hose between the front and rear twin turbo pipes
Also on the cold side waiting on a thermostat and a few other bits and pieces
Cheers
Ok so update time
New parts arrived
Under plenum water/vac lines were abit sad so i bought a new one, im tossing up the idea of just buying every external water/oil/vaccum pipe brand new
I then pulled off the vaccum chamber and replaced the o rings
Most are for vaccum but the 3 small ones are for coolant
There were also some dodgy looking bolts for the clutch fan, so i fitted up brand new oem studs
Also picked up some seatbelt stalks, both pairs of seats i bought were missing these, surprisingly hard to find these
I also did abit of a parts run down to the gold coast
Picked up a centre console, Powersteering pump, steering wheel, nismo front strut brace, a parcel shelf and a brand new oem n1 reo bar
Nismo brace is abit fruity but itll come up nice after a resto
N1 reo trial fit
Shitty picture but a brand new twin turbo badge
The bay prerty much stripped for painting
Going to remove the front guards, 2 remaining brake lines and the brake/clutch boosters
Shes booked for the bay painting in 2/3weeks time so fingers crossed this goes to plan
The bay is filthy, white doesn't help either, I've cleaned alot of the soot off with wax and grease remover, so its probably half as bad as it was lol.
The second steering wheel i bought because this happened
So i needed a wheel to push it around with, once i bought the second gtr wheel i noticed there are differences between the two and with abit of research there is s1 and s2 wheels.
My gtr is a 1992 series 2, and unfortunately the wheel i had restored is a 89-91 series 1 wheel and it may not fit
Which is abit sad so i may have to sell it.
Thanks for the heads up guys, hicas is removed so it should be all good yeh?
Haha its a cheap chinese piece of crap wheel lol
Removing the wheel it snapped, a proper wheel should have strong spokes that tie into a metal ring for the outer circle of the wheel
This thing has some flimsy metal for the spokes and thats it
received_975927809111032_zpsnotttejj.jpe
From the front the spokes are slightly thinner on the s1 wheel, the horn button is different and they aren't interchangeable between s1 and s2
received_975928599110953_zps7fhs6epn.jpe
From the back the s1 wheel has a round plastic surround
The s2 has the plastic extend out to the spokes with a screw on each spoke to secure, and you'll notice the holes in the rear plastic housing are offset in s1 and straight up and down on the s2
So now i need to chase down a s2 gtr horn button and get tge s2 wheel restored by the looks.
So i had to get the puller out to get the wheel off lol, with the fine spline they really hold on
So the s1 wheel fits a s2 fine its just the wire for the horn is different, so i think ill run the s1 wheel, thinner spokes appeal to me more
So i put in an order for all the little plastic pipe organizers in the bay, surprisingly alot of them
And I've basically taken every bracket/pipe/pulley i have and dropped off to my local powdercoater to have refinished
So all mint brackets and stuff should set off the engine bay being freshly painted white
320kw.
Engine bay is gunna look a million bucks after a paint. That bitch is filthy!
Hmm I might look at the gears then, better to do it now than do a motor
Priced up Reimax gears, similar price to the spool gears, is any brand in particular better?
Yeh the previous owner really made a mess in there sadly
Alrighty then abit more progress
New thermostat turned up, slightly different design to the original one
I was waiting on the thermostat to fit the coolant necks, so abit of toyota grey fipg and they are on
Mounted up the front coolant pipe to the cam belt cover with some nice new stainless bolts
New oil drain hoses
Fitted up nicely, also fitted the original lower heat shield, and all the support brackets with new bolts
The remaining banjo bolts turned up, new vs old,  they don't age well
Tried polishing the cas but because it's poor quality cast alloy it doesn't polish well, so black it is
Inner guard liners removed and cleaned the wheel arches with wax and grease remover
I also nearly forgot to add the pic of my front pipe
received_977235842313562_zpsopwh5fbr.jpe
It was unknown what brand it was, turns out its a mines stainless steel front pipe and rrp is  $1050 new in japan :-o
Alright a small update
Parts back from powdercoating
Picked up some new stainless steel cap screws for them so it looks brand new, i just need an original nismo strut brace decal which ill be ordering tonight
Pretty happy with how it came out, itll get put on the shelf till the rest of the bay is finished
So I've removed the wheels and started looking at them, deciding what i should do with them, restore them or sell them, i think ill have a crack at restoring them
Ive ordered some nicer style ssr centre caps but they require mods to the hub bore, also had some decals made up as replicas of the original, i got 2 sets done 1 with white writing and one with black.
I can't decide if i should colour match the centre's white or do them kh1 r32 gtr gunmetal or just gloss black
Whats people's thoughts?
The centre of the wheel is pretty unusual where the centre cap goes
Here are the decals i had made, abit hard to make out the white ones
So as you guys have probably noticed I like my stuff pretty original so I ordered 2 of these
2e276de6bf429d973225762b46da13f4_zpsw7zv
Available in silver or gold, I ordered 2 silver decals, so hopefully they turn up soon, I think it's the small touches that make the car stand out
The whole aim is to make it look period correct 90s jap style
I'm thinking black or gunmetal centres on the SSRs
They are pretty rare wheels so I haven't found much of them in other colours
I did manage to find a guy who refinished his set from silver to black in the UK
e17f53d4d6169aa2627fd83b6b920568_zpsehyn
Before resto
14efcfef4585b341097b38265f0cfbd3_zpsfhug
After resto
I also had thoughts of satin black but still not sure
The more input the better
1 hour ago, jmknights93 said:
Where did you order those old style nismo stickers???
I'll send you a pm man
8 minutes ago, SiR_RB said:
Mad work so far !
watching this thread closely, love the attention to detail☺️
Thanks, appreciate the comments
  • Like 1
    • Here's a boring history lesson on number plates People want illegal spacing to make their plate more readable, if mine was J2X BK, anyone who knows about the car would see that its spelling JZX. Years ago third party plate manufacturers could alter the text to make it look like something else, nowadays the computer software is locks that ability (well, ours does at work) Up until 2001 the first letter of a number plate represented the year of the vehicle, for example A would be 1983. (pre 1983, the format was backwards, so the year letter was on the end). Followed by 3 random numbers and 3 random letters. Things started to get complicated at the end of the 90s where T and V were 1999, W and X were 2000 and Y was early 2001. From 2001 they introduced a new 'layout' where the first two characters are letters, this represented where that vehicle was first registered in the country. The letters corrosponded to a region in the country. Some regions had a large number of codes, where as some only had a couple (despite being large in physical land size) Next are 2 numbers to indicate 2000s. So it went from: Y (March 1999 > Aug 2000) 51 (Sept 2001 > Feb 2002) 02 (March 2002 > Aug 2002) 52 (Sept 2002 > Feb 2003) etc etc When the 2010s got here, the numbers changed again, going up by tens 10 (March 2010 > Aug 2010) 60 (Sept 2010 > Feb 2011) When the 2020s arrived it went to 20 (March 2020 > Aug 2020) 70 (Sept 2020 > Feb 2021) etc As for personalised plates, you're not allowed a registration that makes the vehicle look newer. Take my 110 for example, its a 2004 car so I can have any available plate upto 04. I can't have a 54 because it was manufactured in August 2004. Which allows me to have a J plate, because its older (if that makes sense)
    • Mount some of these on your dash? https://www.greddy.com/products/16001720
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
