On 12/17/2016 at 4:31 PM, Happy Seal said:
I tried out the 8374 and 7670 on an HKS bottom mount. Issue with the 8374 was the compressor inlet sits too close to the engine mount and also fouls the oil supply port on the block. 7670 sits much better, will have to use a sharp angle for the intake pipe right off the compressor to clear the mount. I'll dig up some pics and post them later. . .
old solution was to add a spacer
Think you'll find he means response, not necessarily rpm on a dyno plot.  I'd not count on the EFR to show a heap of improvement on a boost curve on a dyno plot - but if you get two otherwise identical cars side by side and step on the throttle from 3500rpm from vacuum you may see something more tangible.
I get it :)
I have 8375 .92 T4 divided in my forged Rb26 and HKS 264 cams on fuel pump ,and it's a bit laggy i running 21psi it's street fast car but it push hard after 4300.
My power goal with ~2.6l capacity is 420rwkw on fuel pump 98 till 8200 rpms, 8374 with hotside .92 is the best way for fast daily car with 420rwkw? The little problem is that hotside is huge and i have little space :(
One page ago i read 7670 is for max 375rwkw, with 1.05 hot side also? But also it's information the compressor is for 640hp so maybe with 1.05 it can make that close 400rwkw in 2.6l?
Edited by joe89
the older s300 8375 0.91 makes 1 bar boost around 3900-4000rpm
the EFR 8374 makes 1 bar boost around 3500rpm.  Considering your goal to make power to 8200rpm i think the external WG 1.05 a/r would be your best bet
  • Like 1
on a twin scroll manifold with twin gates you will get 33psi by 4400 on an rb26
in hindsight, I should have gone a twin gate setup as my single 60mm old tech gate seems to be causing lag on my 8374. I get 29 psi around 4400 whereas my mates 32 GTR with a built 26 twin gate will see 33psi on similar revs.
Any theory on why that would be the case?  While they are spooling the gates should be both closed, if the system is correctly divided and sealed up to the gate then surely everything should behave the same
This is a bit of an interesting one.
Over the years I've heard some pretty wild claims with using two gates vs one gate on a twin scroll single turbo setup. 200 RPM, 400 RPM, 500 RPM even 800 RPM.
Has there been anyone that's done some sort of back to back with it?
If there was no gain AT ALL why do people use twin gates in the first place? It would certainly save a lot of money in hardware and fab work that's for sure!
25 minutes ago, sneakey pete said:
I belive you quoted the wrong post and were replying to umair, but that's assuming that it is divided right to the gate?
You're quite right, and I can't edit the post :( And yes, that was my assumption - I stated that in the comment :)
Never heard of a back to back, and there has been some pretty strong argument for it - the argument FOR makes sense in terms of "on gate" behaviour but when most of the claims relate to spool and on-boost behaviour, in which situations there should be no difference at all I don't know what the story is.  Fwiw everyone I know that have done single gate setups have done the manifolds more or less how you'd expect from twin gates, as in sets of 3 cylinders have individual feeds which merge at the gate but pretty much the only way that the two pairs of 3 can interact are from the point the gate opens.    In terms of the tubing while the gate is closed I'd expect that the gases shouldn't know much, if any difference from if it were twin gate - and the performance that guys I know who are running single gate setups as I describe is decent, to be fair if they got 500rpm better spool from what they have currently then they'd be rewriting the rules on spool with a given turbo size!
I think the logic might be pretty simple on this one.
The whole idea of twin scroll turbos is of course to acoustically isolate the two halves of the exhaust stream.  There are nozzles at the turbine inlet that serve as the "end" of the exhaust path, as far as the manifold is concerned.  Therefore if you have no wastegates at all, whilst the exhaust might merge at the turbine, the two halves are isolated from each other at the point.  The acoustic wave reflections bounce back from the nozzles and the exhaust is properly split.
But if you put a single wastegate onto a split pulse manifold then it forms a bridge between the two halves of the manifold.  It doesn't matter that there's no flow down those pipes when the gate is closed and you're trying to spool the turbo.  What matters is that the pressure pulses can travel down the (currently) active half's leg to the wastegate, then go back over to the (currently) inactive half of the exhaust.  Thus wasting the exhaust pulse energy that you paid extra for (in the turbine housing and the manifold).
Twin gates keep it all separate.  So on spool up the split pulse thing does what it is supposed to.
Let me get this straight, There are 3 pipes meeting a dead end at a closed valve, and a separate 3 pipes meeting at a dead end at a closed valve, somehow the pulses from cyl 1-3 pipes will interact with the pulses from the other 3 cylinders despite (beyond maybe ever so slight leaks if there is not a perfect seal with the fabrication) there being no clear path to get there?  Sort of like quantum entanglement?
What you describe would make sense if you were a useless flamin mongrel and just joined 1-3 and 4-6 into a single pipe and had THAT meet the gate, but I'm talking about is what I described above - so there is literally a divider in the middle of the manifold's WG flange which keeps 1-3 and 4-6 separate at the join to the wastegate.
But is it not universally the case that the wastegate does not isolate the two pipes leading to it?  How could it?  it's not as if there is any divider inside it.  It's just a poppet valve with one inlet.  The pipes have to join, either 10 feet away or 1 inch away, it doesn't matter.
So this divider extends to the face of the poppet, and there is a full seal between manifold and gate.  Any imperfection there is enough to completely screw any advantages of having a divided housing?
Edited by Lithium
I'd say you'd want to have a tight seal agains tthe face of the gate for the inter pipe divider if you did go single...
I think there's another layer of confusion here as any potential difference might show up on the street but not on a dyno?
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
