On 7/2/2017 at 1:25 AM, MotHot said:
Oohh, shiny
Looking forward to your results, hope everything comes together nicely!
So far so good! Nearly ready for the tune... Just been tidying up some small stuff while its at Fabtech...
It all runs and is nice and quiet with the new stainless exhaust system... It no longer sounds like a tug boat at idle :laugh:
Will be interesting to see what it sounds like at full noise!
Where's all the twins at?!?!?!!?
Here's my lump of coal. Scooped these baddies up in 2012 and they got installed just 3 months ago. Long story short this build has been in the toilet since 2011 and has gone through 2 builds which neither lasted. These 5 year old turbos ran for 2 seconds (total time since purchase lol) just a few days ago, literally, and the tomei engine failed due to seized exhaust cam on bearing cap 1. Anyway, maybe some day I'll have dyno charts for them. Don't mind all the colors, ran out of budget for paint lol.
  • Like 2
quick question for those running an 8374 or larger,
got the 8374 running a few weeks ago and mine makes a bit of a siren sound during low rpm spool that I'm used to with things like  HKS T51R turbos and the like, but is the siren sound normal on the B2 Frame EFRs?
sounds like the full race R14 in this video but not as loud.
That sound to me if it was a non anti-surge cover turbo would signal a damaged turbo. looking around youtube it appears some do it and some don't, could be camera mics or something I guess?
Edited by burn4005
  • Like 1
9174 is going on a mates car, Nitto 2.7 with head work.
engine should be done in a few weeks.
I've got ~460awkw on the 8374 on my car and that's enough for me, my getrag and my clutch for the time being.
but if the 9174 turns out to be a no brainer then I guess I'll be doing it too eventually..I'm holding off for a black series 8474  for the time being if that ever happens.
Edited by burn4005
  • Like 1
Sorry I may have missed your results, what capacity is your engine and what exhaust housing do you have on the 8374. 460awak @ what boost?
engine is 2.63l (87mm)
1.05 rear housing, about 30psi and full boost reached at about 4700rpm. could probably lean on it a bit more timing wise up top and a bit more to do on cams (260 poncams)
6 boost single waste gate manifold with divider to the valve face.
quite similar result to FAT33R.. I suspect he's making a fair bit more up top due to the screamer.
Edited by burn4005
  • Like 1
unfortunately no sensor, will be doing further dynoing soon to improve TPS boost control, throttle enrichment stuff and Map the atessa duty to a torque split ratio value.
I have a sensor on the turbo now.
will FINALLY also get some high speed logs (100hz) of turbo response off boost, between gears, coasting high rpm to WOT etc. i think we're all due for those numbers after 7 years of talking about the response of an EFR!
Edited by burn4005
  • Like 5
How do you find it, data aside?
Would be interesting to see your mph.
Mine was 2psi short on the night and i ran 134mph so id expect 136-138mph with 31psi down its throat.
I have the car back. First test drive around the street was positive. Way, way, better tham the old tomei ARMS (that being said that's not a huge compliment)
Things making boost easily, can comfortably drive it around the streets with no dramas. It does still feel like a big turbo though, part of me does think that maybe i should have got a 7670. That being said i'm sure that will change with E85 and timing and making more than 400kw with more boost.
Is it tuned?  Or is this just running around on the previously mentioned 7-9psi?    There is definitely no magic, these things (particularly the 8374 and the 9180) are still large turbos - they just are very responsive for the flow they provide.  E85 and well over 400kw will make it all make much more sense :)
yes, still just on 98, 7psi spring in the gate; no boost control, and only 9 degrees of timing if i remeber correctly.
In the coming days i'll sort out a few gremlins and get the courage up to actually venture a bit further and out into the countryside and get a better idea of how it performs, so i'll have some more detailed thoughts then.
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
