1 hour ago, sneakey pete said:
Not sure why mines 700rpm later with the same cams
Guess more tuning will help a little.
You can always pull out timing so the EGTs are hot "turn" the turbo on, but torque with low timing at that load point vs. the torque with less boost at that load point with more timing could be drastically different.
Bugger boost levels. Whatever gives the most Nm. 300 Nm and 2 psi is better than 150 Nm and 17 psi. But Boost is higher so must be better yeah? ?
hahahah depends on the user, some want instant boost for the head snaps, some what linear and flat torque to minimize wheel spin and get good lap times :)
Customer is always right!
  • Like 1
For anyone who is interested
8374 with 1.05 rear on standard 2.6 engine on e85
Tyres with 275 Mickey Thompsons.
10.7 @ 133mph in Sydney summer. Was running 28psi on the night.
Will go again in winter and see how much of a difference the MPH makes.
  • Like 2
Soft timing doesn't make the boost come on instantly or even necessarily much or any faster time vs psi, but yeah it does make for a more violent torque transition on spool which some people like.  Have to admit I've done similar things with valve timing etc where people wanted a slower car that they liked the feel of more.  Nothing wrong with that, either.
Edited by Lithium
What tyres were you running cause that’s a pretty good 60ft
I'm just fitting a 26/30 in a cefiro. It's an r34 head that's been reco'd,  stock low km rb30 bottom end with head studs and new oil pump.
I have a 9174 ewg 1.05 and twin 40 mm gates I was going to put on my gtr.
Should I fit this to the cefiro now and buy another one for gtr later?
Is it overkill for a stock bottom end  as I was thinking 20 psi Max on this combo on p98 as I have the fuel system now to support 550 whp?
Not sure how far to push the 2630.
4 hours ago, Piggaz said:
How modified is your head?
How big is your exhaust?
Where are the cams set? (Mine are 0/0)
Finalise the tune and see what happens.
Whats holding the final tune up? It’s been ages!
1mm OS valves, 3.5" all the way, 0/0 also.
In terms of getting the tune done, the usual. Work, Life, the oil squirter coming out the sump. those kind of things. Hopefully get closer to it by march.
Thats a huge MPH - i always thought low to mid 120s would be a high 10
modern DSG, AWD, Launch Enabled cars yes - older things like our dinosaurs would need 130~140MPH to get it to boogie
  • Like 1
this is a long shot but i may as well ask the question and get thoughts of the guys on here.
Currently have a 8374 w 1.05 rear on a custom CRG manifold. The manifold was designed specifically with my turbo specs in mind.
I'm contemplating upgrading to a 9180 w 1.45 rear (with eventual goal and having a stroked motor), however at this stage the upgrade only seems viable if the turbo is a straight swap.
The concern is the 9180 with the bigger rear housing may not fit on to the current manifold.
I wanted to check if anyone on here has had experience with both 1.05 and 1.45 rear housings and is able to comment if the bigger rear would work with current manifold. Don't really want to dick around with new manifolds etc etc so won't proceed if it is not a straight swap.
Appreciate it is not a straightforward answer, however thought I'd check anyway.
Cheers
I believe the dump pipe has to move back 7-8 mm. Going to dummy fit mine soon. Seems like if you want to use all of the available compressor in both the 8374 and 9180 (moreso) the 1.45 is needed.
what about your manifold though? will it fit such a larger rear?
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
    • yeh they are 235/45/17 up front and 255/40/17 in the rears. I still didn't get my answer if i can fit a 18x9 up front. I want to get 4 of this and see if they will fit before committing as they didn't see an 18x8 as an option but there is a 18x9.5 also.   Enkei RS05-RR 18x9 35mm ET 5x114.3 75.0 Bore Matte Gunmetal Wheel
