3 hours ago, Full-Race Geoff said:
The 9180 1.05 can easily supply 500rwkw worth of airflow.  the rest of the setup will need to support this, fuel is the biggest factor (knock)
Full-Race has a few in stock, there will be a sale for the big holiday in the states this weekend
BTW, I meant awkw, not rwkw.
21 minutes ago, Piggaz said:
Piss it in. 8374/1.45 on my setup went 517 AWKW at 122,000 turbine RPM. 490 AWKW with the 1.05 bum.
Thanks mate. Is that on a 2.8 and on 98 or flex? Looks like you were just under the line there - for the 8374, is it 125k max shaft. speed?
Paul , you have had the 1.45 on for a while now and at first you were sort of thinking about switching back to the 1.05.
You have had a few runs now and one today with Dan , have you made your mind up yet ?
2 hours ago, Nismo 3.2ish said:
you have had a few runs now and one today with Dan , have you made your mind up yet ?
Nugget. Spending money on the wrong things, needs a shift boot and a front lip ffs.
I am too upset to talk about it in depth right now but will update with more when I am back in NZ ?;)
Edited by Lithium
56 minutes ago, fatz said:
1.45 no good?
Dont they make like 4 million kw in seppo land?
1.45 has its place. Did the Huntley hill climb today and just doodling through it at a corner that I had huge issues with the twins, it was ready to turn tyres.
I won’t be going back to the 1.05. Sub 3000 RPM there is Definately a penalty to pay, it feels a bit “soft”, from 4000 RPM it’s fine. If you’re “driving it” it’s all there. The 0.92 IMO should be made redundant IMO. No need for it.
Still well infront is the -5’s that we’re on it either way.
Without the head work you have done and slightly higher CR 9.1 ish , would the 1.45 still give you what you want or just lag it to much for what you like in a Street car
Guess without some sort of comparison it would be hard to know how much difference it would make .
Stock head no.
Depends on what you want, what you’re happy with. Having driven both, I would want my cake and eat it too. If the engine ever comes out I’ll throw a V cam at it and possibly bump the compression up a tad higher. Cake and eat it too?
As you know I am thinking of doing some headwork ( never ends lol) wondering if anyone has a 3.0 or 3.2 Lt that has has the compression increased  up to 10.5 ish   , mine is down to 8.1 for whatever reason during work on the stroker build ?
Maybe also done  some port & polish work?
Back to back Dyno runs would be great
I will stick with the 8374/1.05
Of course you should do that.  8:1 is 1980s CR for boost.  But you won't get that increase by changing the head. You'll need pistons.
20% increase in capacity means a 20% increase in head flow wouldn't be a bad idea.  Easily achieved with sensible porting.  1mm bigger valves gives the perfect opportunity to properly do the seat angles and shape the bowl into the back of the seats.  And there goes 5 grand.
A decent full effort head costs as much as the bottom end. That’s where the last 15% of performance is found. Depends on how much that last bit is worth to you.
Sort it out Pete!
There will have to be new pistons to go with the new work, it will have to be done properly especially with the Vcam in the car, I already have 1mm OS valves
i decided that if I am going to pull the donk down, get it all done at the same time
Wouldn’t do it if I did not have E85 close by now ?
Sort it out Pete!
Yeah mate , as you know I have been tossing it around for a long time and can’t help myself, must do it , have to feel the difference when I press the peddle, like an Fn drug ?
Just now, fatz said:
Pulling down a running motor is just dumb
just saying
break then fix
Know what you mean but I am not going to break it anytime soon and at 76 , F it I want to finish It , just wish I knew what I wanted at the getgo, but I think there are many blokes doing work on their cars and the goal posts just seem to keep moving
But I had no idea I would go this far , it just gets in your blood like herpies and just keeps coming back when you think it over ?
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
