Thanks for the replies,
Yes I never thought of the IWG plumbed into DP causing the flow issues.
Either way, I will install a cutout valve in my Downpipe so It should solve the flow issues. Was thinking otherwise I have to go 4" exhaust like GTSoy said.
Geoff, yeah you guys have been great through my build (also ran a 7163). I am concerned about running EWG as both space and heat are an issue for me. This is a dedicated track car (more time attack) now and only at Sepang F1 Circuit which sees 52 degrees °C track temp.. I have seen a few EWG struggle with heat due to placement in Evo X. I would much prefer an exhaust cut out in downpipe over twin EWG setup. for my IWG I have never had an issue holding boost flat up top.
I recently changed to the 4 port boost control and twin port IWG turbosmart unit (which got me the 2bar @ 3,90rpm in 4th gear) and holds flat to 8000rpm.  to be fair I have slightly different gear ratios to a stock EVO (sequential 6 speed)
Shooting for 650whp (on a mainline) with the next round of tuning.
Rob
hi rob,
I agree with your decisions here.  For my personal projects, I prefer IWG for the exact reasons you outlined.  The Exhaust cutout near to the turbo will help.  But be careful to choose a high quality cutout (i have seen many fail).  also you may find 3.5" is suitable and 4" does not offer any benefit
Of course the 4b11T is backpressure sensitive so the 4 port solenoid with a twin port IWG is a good way to get boost where you want it.  Long term I believe the electronic stepper actuators may prove to be an ideal control system
Edited by Full-Race Geoff
Hey guys, I have a EFR 9280 with a 1.45 a/r exhaust side. I have a RB26/30 block with Hypertune cam covers in a R32 GTR. What manifold are you guys running that fits this turbo on this car? I'm currently talking to Full-Race but it is not clear if the exhaust side will clear. Jon said that some modification might need to be done to the cam covers, which is not acceptable to me. Any ideas?
Edited by minesskyline
On 4/6/2020 at 6:40 PM, Robo said:
 8374 , my setup is sleeved block 2.2ltr (4 cyl obviously) with direct port meth injection, sequential 6 speed, head work, oversized valves and makes over 600awhp on a mainline dyno  peak power is 8500rpm and I get 2 bar of boost by 3,900rpm in 4th gear. Car weighs 1280kg after stripping it (with roll cage) and being built for Sepang F1 circuit.
what boost pressure? did you have at peak '600awhp' power
Hey there,
I had exactly 2.0bar, it was completely flat all the way across the upper rpm range. This peak was at 8,500rpm where we stopped the run.
in other news, I have just finished my side cutout in downpipe:
Edited by Robo
52 minutes ago, Robo said:
Hey there,
Thanks for that ;)
oh be careful with those type of flex joints, customer of mine had one fail in his car a few weeks ago they collapse in on them selves to about 1/2 the normal diameter under sustained load at high heat.
On 4/18/2020 at 9:21 PM, RICE RACING said:
Thanks for that ;)
Thanks for the heads up,
This one is double layered and has been on there for over 4 years now, will inform the workshop.
Rob
here is a photo of the 1.45 a/r EFR9280 on our manifold installed in R34. I do not know for fact - but I suspect R34 RB26 valve covers may have more clearance than R32/R33
RB20 valve covers may fit also (a friend installed them on his 26, looks really cool actually) and smaller than RB26
Thanks for that. I have Hypertune cam covers, so not sure if the dimensions on these are smaller or not, but I know they are lower. Aren't the position of the shocks different than a R32 GTR? Would Full-Race be willing to allow me to return the manifold if it doesn't fit? I asked Jon this question but I haven't received a response yet.
On 4/18/2020 at 10:27 PM, Robo said:
Hey there,
Thanks Rob,
We are going to slap on one of these 8374 Full Race kits to a built 2.2 on EVOX, not going for internet records just increase the specific power while keeping some response, will let you know how it goes ;)
On 04/05/2020 at 10:44 PM, jshimer23 said:
Finishing up a RB3026 build with Full Race 6258 twins setup. Kelford 272 cams, 4.375 gears.
Green line is E85 and 28psi. Red line is pump 93 and 20psi.
Any idea where the little dip from 4,4-4,6k rpm comes from?
Making 50% of max power by 4500, that's amazing.  Tempting me to switch from my 8474 to twin 6258s
Is anybody able to take measurements of the EFR9280 compressor, I'm seeing if I have enough clearance on my engine to run and test it compared to the 9180 which I have on me which fit fine on a 6boost T4 in a R33 GTR engine bay
Edited by RB335
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
