Hello. I am in the finishing stages of a 3.2L gtr build and was settled on using g a G42-1450 but the more I read about the 9280, the more I'm starting to sway. It won't give me the same peak power but might make it a faster car due to better responce and torque while still netting a 4 digit dyno sheet. Im thinking 1.45 twin scroll rear housing. What do you guys think?
The power target would be helpful with this discussion
Generally speaking, most people I know who have tried the EFR9280 have not been particularly blown away so far, exhaust back pressure seems to be a thing - especially on bigger engines... if you're going to do it then the 1.45a/r hotside is the only option I'd consider.  The G42 1450 is definitely going to flow better but also most definitely comes at an impact to response, in fact one of the guys I know went to a G42 1200 from an EFR9280 and that delivers power in the higher rpm better but even that turbo added reasonable lag over the EFR.
  • Like 1
Interesting that everyone is saying back pressure is a thing  - I assume that is only once you starting pressing out 900+hp?
Here is my 8474 using 1.05A/R on 3.2L Nitto.  about 750hp at hubs.     eMAP/MAP is rarely over 1.2:1  as you can see here 1.17:1 @7515rpm
Yes circuit car, not Drag car - but I guess I this would be around 800-820hp at the engine - at what point does exahsut pressure become a problem - ?   Or do you think I already have a problem...?
Nice!  Awesome to finally see some data on the EFR8474 looks really solid in terms of what the data is saying about it - I'd be happy with that EMAP at that power.  What is odd though, and seems to be a bit of a trend...  where your IMAP is, and where your turbine speed is lines up with 90lb/min of compressor flow.   Do you reckon you're making the power you'd expect when your compressor speed and boost level suggest you are pushing at least 90lb/min of air?  This is part of what I've been told from people who have tried black series EFRs, they aren't getting the numbers they were expecting before they run out of compressor speed but perhaps the expectations need to be adjusted?
And yeah, the back pressure comment was about people looking at making use of the >100lb/min rated compressor flow of an EFR9280 - so closer to the 1000hp @ hubs territory, unfortunately I don't have first hand data so much as just going from people who I'm spoken to who have used them.
  • Like 1
back pressure not relevant to compressor flow. (in the context of the operating point on a compressor map. yes, it affects VE)
but remember that 2.6 bar gauge inlet pressure will end up being more like 3.7 absolute PR (Possibly higher) once you factor in the inlet filter and intercooler pressure drops, which crosses closer to low 80s flow point at that wheel speed.
i'd be happy with 750hp at the hubs at this operating point. 900 at the hubs through diffs and gearbox flowing ~85lb/min is asking a bit much isn't it?
the Motec will have a logged VE calculated airflow. if your injector data is good and you lambda=target the Motec calculated airflow will be accurate if you wanted to verify.
Edited by burn4005
  • Like 1
Sorry what I meant was, in answer to this question - "Do you reckon you're making the power you'd expect when your compressor speed and boost level suggest you are pushing at least 90lb/min of air?"    -  I'd say 'I think so',  given the restriction to overall flow caused by eMAP.
Would that be correct?  Or am I misunderstanding?
Probably misunderstanding. The compressor map should be viewed as a statement of fact. If the shaft speed is Z and the PR is Y, then the flow on the X axis that corresponds to that operating point is what the turbo is flowing. That flow is happening regardless of the restriction caused by the EMAP. If the EMAP were some different value and your turbo was operating at that same point, the flow would still be the same value. Make sense?
I think the element of surprise exhibited by other posters above is that the operating point you describe sounds like you shoudl be making more power than you think you are, which starts to throw some doubt on the factiness of the compressor map (or perhaps the measurements you have to put the operating point on the map).
  • Like 2
The trick is there seems to be a trend of this from the few black series EFRs I've seen results in, at least one tuner I've spoken to has decided it's a back pressure issue but this data doesn't suggest that to me.  The trick is I don't know where to go with it beyond the possibility that the compressor map or something about the data is not accurate which I'm not going to leap to concluding.
If you follow the compressor map the line where 116,000rpm sits hovers over 90lb/min until about PR3.2 which I would be surprised if it is reaching that high, but never know.
Fwiw Gen2 GTX3582Rs fall fairly short of 90lb/min on the compressor maps and cars have made more power at the hubs than this on E85.  Not hating at all, I would prefer an 8474 over a GTX3582 but there are things I still have some question marks about
Yes all good - the only way for me to know is swap to a GTX3582 or 6466, perhaps 6870 to compare.  A fair bit of money just to experiment though,  and then - will I miss how it drives...?     that said the 8474 is noticeably lazy compared to the 8374 for just an inducer change.  Its not the "same down low but more up top" the internet seems to suggest.
Edited by R32 TT
You know Elon Muskrat has won a contract with the Lebanese space agency to make a special Uranus probe lander mission using emotionaltron ECU and GTST body shell with special hiflow fitted with EFR black series internals using all the hypothesis off this forum, he was saying the key is the independent staged drive by wire and keeping the turbo on the small side cause when you do a hektik launch everyone knows that its area under the curve that is important when going to Uranus
  • Haha 1
Yes, yes... Come to the dark side
  • Like 1
  • Haha 2
Run an OPR and an oil filter and they will last, at least they won't shit out turbine wheels if you accidentally over speed them :)
Have been over speeding my 8374 by a few 1000 rpm since the day it was put on 2017. Was pulled off a few weeks ago in perfect condition. No shaft play, no missing turbine wheel. 🤷‍♂️
  • Like 2
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
