So looks like it worked a treat, cathode side on the +ve terminal.
Also noticed the SSR isn't running as hot anymore, explains why they were all dying after some time. When I got back home after the drive with @PLYNX and my mate, I was actually only running on one pump as I previously had 2x SSRs running side by side but without heatsinks. I decided to convert to a single SSR with a large heatsink for simplicity, and that's when I noticed the issue with my setup.
Anyhow, I found this diagram from another brand name SSR and they specify that all inductive loads must be suppressed by a fly back diode.
Running at 90%
Will start to lower it soon when my laptop is charged and keep dropping it till the fuel pressure starts to drop and raise it by 10%
  • Like 3
1 hour ago, Looney_Head said:
Hi Dose, do you have the part number for the diode you used? i need to do this for my SSR before i cook another one...
This is the one I used :)
https://www.jaycar.com.au/diode-1n5822-schottky-40v-3a-do-27/p/ZR1048
  • Like 1
Hi Johnny,
Love the build, it gives me the much motivation needed to get into my 33.. I am really keen to know more about the details of your PWM setup, any chance you are you able to provide a wiring diagram on how you set yours up? Size of wiring and fuses etc? There so much conflicting info on the interwebs, however, it seems like you have refined the setup nicely.
Cheers
@R3N3 wiring diagram is pretty much this:
Output 1 is +ve battery
Output 2 goes to your fuel pump(s)
Input 3 is +ve IGN
Input 4 is the PWM output from your ECU
Battery -> Output 1, just regular 8GA audio wiring. Used a audio style 80AMP ANL fuse.
Output 2 -> goes to a fuse block, with 2x 30AMP fuses, used decent gauge wiring to the fuel pumps
Fuel pump side, used 2x Schottky 40V 3A diodes, cathode side on the positive terminal of the fuel pump. Remember that current travels from +ve to -ve, but voltage the other way around.
Input 3 is +ve IGN
Legend. Thanks
14 minutes ago, R3N3 said:
Legend. Thanks
Shit just noticed I made a mistake,
OUTPUT 1 to pump
OUTPUT 2 to battery.
Ironic the wiring diagram was in my face and I still managed to cock it up. Shows males can't multitask
37 minutes ago, robbo_rb180 said:
Johnny how have you found having the pumps PWM controlled? lower/consisstant fuel temps?
Keen for bathroom updates.
Good question, I went on a 4 hour drive not long ago, I should download that data and have a look :)
I'll probably let it sit at room temperature, and used my MAPP brazing torch to sear it... will post pics when I cook it, going Korea first LOL.
@PLYNX hahaha yeah, I might need tyres soon and also I have 2x cars I need to tune this Saturday, trying a 3rd place for dyno hire and waiting for them to get back to me.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
