40 minutes ago, ActionDan said:
Where can I get one?
https://burubado.com/collections/stickers/products/please-do-not-abusing-of-the-motor-sticker
Could ask for foil sticker, so it's like the one pictured
Lockdown dis dat, anyhow after 3 months of shit just sitting in boxes I decided to do something.
Probably the last time I do something for a while too, my back is sore and my hands are dirty now 😅
Was on the market looking for a used one, wow.. people are wanting like $300 for an used condenser, ended getting a new one for $650.
  • Like 2
14 minutes ago, Unzipped Composites said:
Haha... I threw my condenser in the bin when I stripped the car down, imagining that second hand they were worth 3 cents and a mouldy apple core.
It's covid tax, it has ruined the JDM market.
Long gone are the days of running R33 S2 for $5k to $7k 😔
That's why I chose to go to town and respray and send its mum.
  • Like 1
14 hours ago, r32-25t said:
Where did you get the condenser from?
Amayama, worked out cheaper than local because I bought a bunch of stock seals, gromets, interior bits and bobs.
Vega Motorsports guy has them for GT-Rs at a reasonable price.
Just had a look at r32 ones are almost $1200 😞
  • Sad 1
Can we get thread back on track please.
How are you sydney carnts getting 22c feed in tariff, im in newcastle and did the ring around to every company last year and the very best i was offered was 12c. My solar is about 6 years old now though, are you only getting such a good rate because you got Origin to do a complete solar install?
I can't even imagine getting 50+c a kWh lol
Have a look at AGL, apparently they're doing 20c for the first year!
I'm only getting 22c FIT because I'm going with Origin's Solar system (which is overpriced compared to others, but the only way to get the 22c FIT).
17 minutes ago, ActionDan said:
I just got an email saying I can no longer get 10.2 it's now dropping to 6.7... what the f**k.
Time to go shopping!
Yeah I will, hard in Vic, they all vary so much.
The current mob does a 69c day charge and off peak rates all weekend 😕
In good news, I have found some used Tigo's going cheap :)
  • Like 1
Update, here's a full day's worth of data. Pretty nice sunny day, barely any clouds in the sky.
6.6kW system with 17x 390W JA Solar panels (cheap shit) and a 5kW GoodWe inverter (also cheap shit). Origin didn't really have flexibility with their package choices but after reading into it and also the warranty plus Origin's guarantee of craftsmanship I was sold, especially with the 22c FIT.
We have a North facing double storey house with a colorbond roof. Means theoretically we would get better sunlight coverage.
@PranK what is it with these 250px max width thumbnails? Lol.
1233411653_Screenshot_20210704-222920_SEMSPortal.thumb.jpg.6c4c3765e9769a830d1570eabbffe370.jpg
  • Like 1
would be great if there was a newer nissan you could buy the bits from. i need the whole AC assembly apart from the bit under the dash essentially. im looking at a fortune if i want AC back in my car (which i do)
  • Like 1
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
