On 1/5/2022 at 10:48 AM, Dose Pipe Sutututu said:
I purposely made mine blend it and boring looking so it wouldn't stand out, last thing I want is attention.
It's not even low, it's probably in the top 10% of the world's highest R33s LOL
I think this proves my point moreso than yours, this is absolutely a more sporting looking vehicle than a M340i sedan. It is boring to you as you've seen it for many years, this is the human condition 😛
  • Like 3
  • Haha 1
the M340i Wagon sure makes me horny, too bad we don't get it here :(
Mrs Dose Pipe also says no to wagons, SUVs or a UTE(lolwtfbbq yes) only for a family car. I can get a wagon as a daily for myself though :)
On 05/01/2022 at 1:33 PM, r32-25t said:
If need wagon then rs4 will tick the box
Price difference brah, M340i is still dreaming territory in terms of coinage, RS4 is true drug dealer league lol
They were talking M3s at one stage which the price point is closer the the rs4 and then both can see who has the bigger stone attached to their resale value
  • Like 1
On 08/01/2022 at 12:22 PM, SiR_RB said:
More updates less euro trash talk 😂
LOL... bloody surrounded by haters here!
Updates soon, promise :)
Updates to the intake department, using an old intake pipe as a guide. That's going too 😁
Yeah I know, could easily reuse it blah blah blah but I want to sell it as a kit with my old intake cover, catch can setup.
Just final mock ups before it sees the powder coater with the subframe.
  • Like 4
As someone who is just starting to adapt the JSAI alloy airbox into my car..... and realising how 'fun' its gonna be.
What's the bottom line of this look like, the one that follows the chassis, lines, etc?
doesn't really line up to anything down there, I'll snap up some photos when I get the car back :)
So... how does it seal, and not just pull air from the engine bay via the gaps?
there's no real "seal" however there is sufficient air to be drawn from the OEM side mount piping holes, guard, etc.
Would be great to fully seal it and have it suck only chilled external air, however it's a turbo car, with a decent FMIC so I'm not too concerned with the compressor inlet temperature, just as long as the intake air temp is sub 40~50 degrees at full tilt with awful amounts of boost thrown at it.
You don't need to "seal" an airbox, you just need the air coming in to positively pressurise the space enough to stop hot air being drawn in.
Just having an air guide can be enough on its own depending what's feeding it.
Surely having a pod in there removing all of the air in the box will cause it to draw from around the edges? I guess not with an air ram/scoop but the proof is in the IAT's really... but as discussed _less_ important on a turbo car as your intercooler is doing most of the work. But it helps to lessen the load the cooler must do though.
  • Like 1
    • Just to add, I found the r32 gtr ecu the most forgiving, the r33 one would get the shits.
    • For what it’s worth I drove my gtr for over a decade with gt-ss as a true daily after I pulled off the -5s, I had it engineered and went with stock ecu etc.  never skipped a beat.    I would only worry if you can’t get good fuel all the time in a tropical paradise
    • I bought an engine from a friend of a friend many years ago, it was sold to me as a RB25det Neo.    recently I started pulling it apart and noticed that the intake manifold was pretty different from others that I had seen on RB engines so did a bit of research and found that it was a non turbo manifold. So I’m sceptical now that it is a NEO DET and just thinking it’s a NEO DE (it does have a turbo strapped to it currently).    can you identify the engine model from the numbers on the block?
    • Yeah you can. Cable tie the gauge to a windscreen wiper, or run it into the car and hold it with one hand, or have the neighbour's kid run alongside and tell you what it says.
    • I've never understood why this bothers people. Surely you'd be looking at a T3 flanged Garrett style thing, rather than a TD? You're unlikely to push a +T hard enough to need that much fuel. If you're not starting with most of the things you need to do that (ie, the bloody ECU!), you're better off just going Haltech/Link. You wil hate life a lot less. No. Just no. Just turbo it as is.
