On 24/02/2022 at 12:49 PM, Dose Pipe Sutututu said:
Walked in, walked out $550 poorer.
I now have new bonnet/hood insulation 😂
Amayama couldn't source one, Kudos couldn't either, even tried EFI Solutions but somehow Skyline Spares could so yeah, sent it and bought it.
This is more expensive than a coacine addiction.
Different than 33 GTR right ? Also try JP car parts for stuff. They've sourced things for me Amayama hasn't been able to get or said was discontinued.
  • Like 1
It is a bit different, however both are same same in what they do and how they mount.
I haven't even opened the box yet, just added to my parts museum to install one day :D
I must admit, I didn't really try very hard to locate it - but thanks for the tip with JP Car Parts, will try them next time I need more replacement parts for the shit box.
One sensor issues at a time, worked out why my oil temp was reading out of whack.
Turns out when you run a temperature sensors on a SP Input instead of an AV Input the internal pull up is 10k Ohms not 1k Ohms. This means the standard calibration table cannot be used and needs to be offset.
Haltech did supply me a new calibration table to suit, however advised that the resolution will be reduced.
To fix this small issue, I decided to move the EMAP input to SPI2 and move the Oil Temp input to AVI10 (didn't do this initially as I used the OEM power steering input and pinned it to the OEM AFM and it all sat on the main 24 pins connector).
Instead of cutting, crimping and shrinking I decided to swap it on the ECU side AMP plugs. How good are these AMP plugs? No need for any fancy thin depin tools, etc.? Anyhow was a 5 minute job and hello full range and full resolution oil temperature.
  • Like 1
Actually, be really careful with depinning those AMP connectors....I find them an absolute arsehole to work with. The tabs on the locking cap break easily then you are left with a connector that is almost impossible to seat back in properly locked. I ended up buy 2 new ones out of the US (Haltech would not supply) for a fortune.
Also, they are very fiddly with seating the pins at the right depth, initially is OK but if you repin something you have to make sure every wire is still seated properly as they can back out. Pretty much every other style of connector I've worked with is easier, except for those POS pull through ones like in the pressure senders.
*edit* cancel the locking clip rant, that is a different type of AMP lock they used on the smartwire. The one in your pic looks much better (maybe they redesigned after issues)
Edited by Duncan
clarification
  • Like 1
You're probably thinking of this style of Tyco connectors, these are a complete cnut to get right as per your experiences.
The other end to the plug and play adaptor uses these and yes, I've ended up just wiring direct to ECU instead and bypassing them as they're a cnut to work with 😂
yeah those are have a crappy lock too, but I meant these ones
Same pins and similar body to what you have but the red piece does the locking and is brittle. PITA.
Deutsch is the ones when you have a choice, even their big multi pin connectors are great to work with. Expensive tho.
  • Sad 1
I know that plug, great to build once and never look at again lol.
Yes I also hate, and have replaced the entire auxiliary connector before. Depinning it a nightmare.
Cutting and recrimping is easier, that's saying something!
On 28/02/2022 at 8:32 AM, ActionDan said:
I thought you were coming down to wire and tune????
I barely have time to sleep these days, let alone work on race cars that are 2000km away lol
Found a few minutes spare today, turns out they sold me a GT-R one.
Good enough, just 1x clip hole doesn't like up. I have the option of punching a new hole OR drilling one. Still a bit undecided on what path to take but I'll do it one year.
  • Like 1
On 05/03/2022 at 8:11 AM, WantGTR said:
GTR DNA
thats it boys. pack it up.
Nah failed at that one, has a twin scroll single turbo and has VCT.
Needs no VCT, twin turbos for the lags.
  • Like 1
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
